Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 03/06/2019 06:40 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Date: 09/03/2018 08:58 am
Date: 05/28/2017 03:20 pm
Date: 03/07/2017 07:03 pm
Radiator
Date: 05/27/2018 06:07 am
Date: 03/30/2021 12:29 pm
Date: 03/23/2018 09:23 pm
  • Online today: 2,399
  • Guests: 1423
  • Total: 1423
Pinto floor pans available
Started by 71pintoracer, March 06, 2020, 01:02:01 PM
Yep it was quite a project, l have a '76 parts car but it was rusty also. That company has rear pans also
Yep That would rust out the floors for sure , to bad your so far away you could cut out the cowl out of a parts pinto I have to save time and gray hair , going to cut it in six months for a engine mock up stand for a engine swap ,
Working on the cowl now, driver side is rusted out, passenger side is solid.
had to replaced the front drivers side on my 76 , used a replacment pan for a mustang ii , was close enough to look stock , glad the it was just the front I had to replace because it was not long enough to reach the back at all , nice job , make sure the cowl and windsheld is not leaking or it will rust out again ,
You can also get extra metal at each end just let them know how much you need when you place the order. I added 4" to each end, no extra charge.
They look good! But nobody is ever going to see them lol
OK I got the pans and have them put in. Based on the measurements I was expecting a formed pan that would basically drop in with a few modifications. These are just flat sheet metal pans with the original bead design. Quite honestly had I known that and also known that my brother has a bead roller I would have just made my own and rolled some generic beads into a piece of sheet metal. But they are nice pans so if you want the originals they are a great match.
Fronts are $80 each side and they can add extra metal to each end if needed. There are pictures on the Facebook group or you can e-mail Patti for pics
SpaceCowboy1979
How mutch are the frounts
And please let us know what you think
Of them when they arrive and after
Insulation
There is a group on Facebook called Pinto/Bobcat Restoration, they are stamping front and rear floor pans. I just ordered fronts for my wagon since l let it sit outside with a leaky sunroof..... :-[
You can send a request to join the group or you can order by e-mail at patti10@aol.com.
