Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 01/30/2017 01:48 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 03/23/2018 09:23 pm
Date: 07/21/2017 11:49 am
Date: 02/28/2018 09:18 am
front end parts
Date: 03/30/2018 12:48 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
  • Online today: 186
  • Guests: 135
  • Total: 135
72' Hatchback brake drums
Started by 442, February 24, 2020, 02:01:02 AM
442
Thanks for the good information all.  Looks like I will be upgrading the front drums to disc brakes in the near future (thanks 71Pintoracer!).  I will still be replacing the rear drums though, have a "rotational" noise from one of them being out of round I think.  Might be enough meat left to turn them as a last resort, but would rather just replace them.
From looking at the sales brochures, front disc brakes were an option in 71-73 (2.0 engine required for some reason).  I did see a 72 sedan with a 2.0 engine and front drum brakes that looked stock, but who knows.  Front disc brakes were standard on 74-80 Pintos.
From the Rock Auto catalog and vague memory, the 71-73 front drum brake shoes were 2" wide.  There were 2 different rear drums for 71-73.  There was rear brake shoe widths of 1.5" and 1.75".  The 1.75" drum has some small cooling ribs cast on the out side and was on the wagon plus unknown.  The 74-80 rear drums are 1.75" but have a larger center hub hole than the 71-73.  I have used a 74-80 rear drum on a 71 but it takes extra effort to center it while torqueing down the wheel lug nuts.
In addition to the parts stores, you can try placing an ad here in the classified section and watching ebay "Ford Pinto NOS" for one to show up.  Recommend checking return policies before ordering.
PintoMan1
[font=]I think from what I'm seeing in the aftermarket it's a misprint. The picture Rockauto shows for the front is a rear drum. The rear was the same for all of the 6.75 rears. Pretty sure front drums were gone by the wayside after the '72 model.[/font]
[font=]you are right about the pintos with the 1600 having the front drum brakes. but I have a 73 and it had the 1600 in it. it also had the front drums on it. I have since changed all that. now with the 2.0 and disc on the front. from all my years with these cars I have never seen drums on the front of one with the 2.0.  [/font]
1973 pinto runabout
442
That makes sense, looks like the front brake drums are readily available aftermarket but not so much for the rear drums.
I was kinda confused about this post, and yes, the front drums house the bearings, they're not slip off like the rear. I have the complete front drum set from a '71, if anyone wants drum brakes! Ha! But the '71 1600 only had drum brakes and disc brakes were still an an option for the Pinto's with a 2.0!
PintoMan1
front drums are different then the rear. front drums, you have to account for the spindle and wheel bearings. the front slip over the spindle with wheel bearings inside.
1973 pinto runabout
442
Thanks for the info,  I have the stock rear end in it, whatever that was.  I'll probably measure the original drums and make sure they match the ones being sold.
Richard
This site list 71-73 with the front and rear as one and the same. I have no experience of that being accurate. I will caution that the rear brakes on the 8" rear don't work on the earlier cars with the 6-3/4" rear even though the size of the drum can be listed as similar. Hopefully someone who knows 100% will chime in.
https://www.autokrafters.com/p-11229-brake-drum-1971-73-ford-pinto-with-front-and-rear-drums-or-front-disc-rear-drum-909-inch-runabout-d1fz-1126a.aspx
442
Just wondering if the front and back drums are the same on the 72' hatchbacks?  Also, any recommendations on a  source for good quality drums?
Thanks
