Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 04/20/2017 10:10 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 12/20/2016 10:47 pm
1979 pinto
Date: 04/19/2018 02:02 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
  • Online today: 802
  • Guests: 150
  • Total: 150
Timing Belt Bearing 2.0 engine
Started by vegasjerry921, December 31, 2019, 01:22:44 PM
2 short blocks,  l think one has a lightweight crank 5.2 rods and Wiseco pistons, not sure about that l would have to check to be sure. Been a while since l ran the 2.0 so l honestly don't remember! lf someone is really interested l will take it apart and check.  Weiand 4 barrel intake, high rise 2 bbl intake with a holley 2 bbl adapter. Port injection nitrous tubes,Mallory Uni-light distributor, ported/polished head with big valves. Stock head w/ a Ford Motorsport cam, 300/450. Several adjustable cam pulleys, couple of small crank pulleys. And the roller cam set-up, missing one rocker, one spring retainer and 2 lash caps, has springs, big valves. It's an Esslinger set-up, don't know the cam specs but well over .500 lift, maybe closer to .600, still have the ported Esslinger head but the front cam tower is broken, 9500 rpm shifts? Maybe? lol l have a post in classifieds in case l missed something, if there is something in particular you are looking for let me know l might have it,
LongTimeFordMan
If you 2.0 guys are looking for high performance parts l have lots of goodies.....and just found my very rare roller cam set-up....
selling everything to fund my cruising wagon project
vegasjerry921
The complete units are available from Autozone. Mail order only. Part number 9010. They are shipped from SA Gear in Chicago.  Approx $40. plus shipping.
Order on line at Autozone.com . I just ordered and received one. Hopes this helps. ,  Jerry. No. Las Vegas, NV.
1972 Pinto sedan, 27 K actual miles.  All original.
LongTimeFordMan
I got one from autozone
Not sure what the part number was but it fit and worked
And as i remember was about $25
That is good news. Where did you find this discrete info (I love a mystery)?  Thankfully Timing belt idler bearings/wheels are one of the more adaptable items (given the proper tools and adaptation skills) since they are not cog/tooth dependent. The point of greater concern would be getting the tension right.
vegasjerry921
 Pintos 71 thru early 74.  Those of you with the 2.0 engine might like to know I found the bearing number for it. 6203LU. Be sure it comes sealed on both sides.  Some do and some don't .  I would think a machine shop could press off the old one and install the new one.  Hope this helps as that part is getting hard to find.  That bearing is easy to find.  Jerry.
