1976 Pinto runabout
Date: 03/28/2017 08:14 pm
TWM Intake
Date: 08/15/2018 08:20 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
1980 Pinto for sale
Date: 01/06/2017 11:42 pm
Date: 12/31/2017 09:03 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
  • Online today: 628
  • Guests: 531
  • Total: 531
Rear wheel lockup
Started by LongTimeFordMan, November 18, 2019, 12:19:21 PM
LongTimeFordMan
I know 5hat my 73 wagon has a dual circuit master cyllender and safety valve to block off one  ircuit if there 8s a failure but am not sure if it has a true proportioning valve.
Most of the folks arund here who do larger cars insist that there is one but i have  yet to locate it.
I do know that the rear end tends to get loose during both braking and acceleration.
I just installed a rebuilt stock 2.0 with a .040 cut on the bead, stock cam advances about 7 degrees and the 2  1-1/2" SU carbs.
Just some mild mods except that it develops more low end torque.
With the larger carbs  engine starts making power about 2000 rpm and in gravel or a wet road starting out at more than about 1/4 throttle results in wheelspin.
During recent rains here i had occassion to accelerate in 2nd gear from about 25 mph and the rear broke loose and fishtailed.
Not so much on a dry road but i suspect that if I wanted i could get wheelspin as well with more throttle.
On a wet road a panic stop from 35 mph can result in rear wheel.lockup and the rear end swerving a bit and in a hard stop from 45 the car goes sideways.
On a dry road pretty much the same experience with the braking.
Any comments on the proportioning valve
