Date: 06/28/2019 09:14 pm
Date: 02/14/2019 06:27 pm
Date: 11/12/2020 08:28 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 12/30/2022 01:30 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 04/12/2017 06:57 pm
74 pinto
Date: 09/11/2016 06:32 pm
  • Online today: 899
  • Guests: 506
  • Total: 506
brakes
Started by stan, October 19, 2019, 09:46:15 AM
warhead2
I had a similar incident with my chevy blazer. Come to find out that old rubber brake lines brake down inside and make a flapper valve lets fuild in but not out quickly enough. So might try a new rubber brake line if it hasn't been replaced in a long time. Just might be a simple fix.
Sent from my SAMSUNG-SM-G930A using Tapatalk
I have had a similar issue a couple times with other cars when the caliper puck did not retract sufficiently.  One time it was cured by exercising the caliper (collapse with C-clamp and pump up again a few times).  The other time I installed rebuilt calipers when the exercising did not work.  Warped rotors can act like this too, but thankfully I never experienced that.
I suspect what you are referring to as a  proportioning valve is that little rectangular brass device with a wire hooked to it, it is a switch for the brake trouble light and should not cause this.
stan
My front brakes stay on after releasing the bake pedal. Both wheels. Could proportioning valve be the issue. I have installed new master and boaster. Can I by pass the valve and run brake line to front direct from master. Is that possible. 1980 pinto.
mike
