1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 09/12/2018 04:07 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 08/09/2018 07:49 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 08/01/2018 01:17 pm
Date: 04/13/2017 04:56 am
  • Online today: 186
  • Guests: 97
  • Total: 97
1973 Wagon Project
Started by PonyRider62, August 17, 2019, 10:58:11 AM
I stripped mine to the bare metal because I had a lot of pock mark rust spots. I applied about 3-4 coats of Phosphoric Acid as well. I then used a 2K epoxy primer (PCL) and assumed that would hold it for the winter. The car is not garaged but it does have a cover so it doesn't get direct rain. Anyway, it still has a bunch of rust spots showing. So, as a warning don't let your hard work amount to nothing like mine did.
It's NOT easy, but it's well worth the effort!!!  Think how great it's going to look when you're all done!
PonyRider62
Had A Couple Of Semi-Nice Days.
So Decided To Start Sanding The Body!Working On The Top!
Man This Is Hard! Might Leave It Like This And Just Call Her "Spot"
Just Kidding!
Save The Ponies!
PonyRider62
Save The Ponies!
When my Turbo Coupe went to the scrapper it looked like this (below). The 8.8 was removed and the 6.75 Pinto rear was quickly welded into place. The interior was completely gutted. Just a piece of pipe to the rack (one of the few parts concessions I made) for steering. The wheels were the spare and three 13" Pinto wheels. Otherwise this car was gutted of EVERYTHING. Made about $250 selling parts too.
PonyRider62
Thanks For The Input Guys,
Gonna Take My Time To Decide On What Engine I'll Go For.
Gonna Work On The Body For Now!
Save The Ponies!
The 2.8 engine was not a bad engine , (if you keep the valves adjusted it was quite) have one in mne , redone mine years ago with a 2.9 crank and TBI fuel injection , if I had to do it all over again I would have used the 2.9 or even the 4.0 , but I wanted to keep it stock looking and keep the power stearing and must have aircond , still happy with it even though every 15K I have to adjust the valves ,  I still have a V-6 pinto cruse wagon that I am still trying to figure out what to stuff in it , got a 4.0 which I did a fitment and would work with no body cutting ,only they have not made that engine in almost twenty years , along with the 2.3 . 2.0 , 2.9 and over 25 for the 2.8 , next one I am going to see if it will fit is the 3.7 V-6 out of a 2015 mustang  , it was 300 HP and gave 30MPG in the car , fount they make a belhousing to fit the C4 trans to it , looking to that one , last if I could find a wrecked P100D Tesla and swap the drivetrain I would have a high 9 second 4WD Pinto Wagon with fake tailpipes sticking out the back to confuse everyone , but I only have one thing to say , please do not cut on the car and waste it ,seen many that were and later forgotten , hope this give you some ideas , good luck in your engine choice
PonyRider62
Think I'll Get A Cheap Block And Disassemble, Need To Learn About This Engine Anyway.
Save The Ponies!
l have some performance parts listed in the classifieds. l might have a lightweight crank, can't really remember what's in that engine lol!!
PonyRider62
Thanks For The Info On the 2.8
Looking Into Performance Crank And Cam Shafts And Oversized Pistons.
And A 5 Speed Transmission.
Save The Ponies!
l vote 2.0. With a little tuning they are great engines and respond well to slight mods. The 2.8 had a noisy valvetrain, prone to overheating and cracking heads. As far as power to weight ratio they were turds.
PonyRider62
Trying To Decide To Either Build Up The 2.0 Or Go With A 2.8 V6
Need A 73 Back Hatch, And A Windshield.
Save The Ponies!
mando
Looks great. I have a 1973 wagon I'm still working on. are you planing to upgrade the engine? I was planning to place a miata engine and rebuild the stock engine. If you have any ideas let me know. If you need parts let me know. I have a friend who might have what you need or can point you in the right direction.
Have fun.
73 Pinto Wagon
PonyRider62
Working On It!
Weather  Screwing Me Up! Hood, Grill  And Fender Almost Done,
Next Few Weeks Should Be Good!
Save The Ponies!
Renewed from the inside out!
PonyRider62
Finally, Got Time To Post!
Her She Is With New Ball Joints, Coil Springs, Leaf Springs, And Shocks!
Finally She's Off The Ground And Not Dragging Her Belly!
Custom Wheels Next!
Save The Ponies!
PonyRider62
Looked Cool, Didn't Steer For shizod!
Save The Ponies!
Lowering by torch wasn't really that uncommon back in the day.
Is it the best way, nope. but it was done a lot. The "look" was number one. Guys drove cars that barely handled on the street but looked super cool.
Scott Hamilton
Nice wagon!
Sent from my iPhone using Tapatalk Pro
PonyRider62
The Coil Spring On The Left Is One Of the New Ones,
Right One Is One Of The Old Ones, Both Were Like That
Car Was Lowered By Torch!
Save The Ponies!
nectarsis
Quote from: PonyRider62 on December 27, 2019, 11:13:08 AM
Passenger Side, Man It Was Nasty!
Check The Size Difference In Those Springs!
MAN that's scary to see  :o
PINTO LOVE
PonyRider62
Think It's Coming Out Pretty Nice!
Almost Done With It!
Save The Ponies!
PonyRider62
Started With This Old Rusty Thing!
Lots Of Sanding!
Save The Ponies!
PonyRider62
Thanks!
Putting 5 Leaf, Leaf Springs From A 78 In The Rear With New Shocks!
Then I Get To Start Working On The Body! Weather Permitting.
Save The Ponies!
Definitely looks better with the front end up off the ground!  Good job!
SpaceCowboy1979
That is one hell of a way to lower
A car. Lol
I am ready to rebuild my hole frount suspension
It's all tore apart
Just need the money for the parts
Might be a couple mounts
PonyRider62
Oh Boy! Now I Get To Put On The Leaf Springs And Shocks In The Rear!
Save The Ponies!
PonyRider62
The Spring On The Left Is The (New) Spring.
Idiot Lowered It The Mexican Way, Torch The Springs Till They Collapse!
New Ball Joints, Shocks, And (New/Used) Coil Springs!
Hell Of A Job!
But Look At Her Now!
Save The Ponies!
SpaceCowboy1979
Wow
Is the spring on the right side in the
Pic broken or just smashed ?
Hope it didn't cause more damage
To control arms and or hardware.
Please keep the pics coming
PonyRider62
Save The Ponies!
