Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 05/22/2018 01:54 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
hood for a 79-80
Date: 11/30/2018 10:55 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
  • Online today: 1,106
  • Guests: 1055
  • Total: 1055
Does anyone happen to know what thickness the engine frame bracket metal is?
Started by russosborne, March 11, 2019, 04:06:50 AM
Quote from: russosborne on March 12, 2019, 12:46:07 AM
Thanks, all.
Oh, here is what I was asking about.
Yes, that  bracket measured out to .125 (nominal).  As mentioned the shape has a lot to do with the strength. Try elevating a book with a sheet of paper and you get nowhere. Cut the paper in 1" strips, tape the ends together to make circles and it is well supported. It is all about the shape.
  You might want to look at how the 302 V-8 was put in the Mustang II as I assume a 351 in a later Pinto would be similar.  BTW, the bracket above (post #6, pic #2) is a '74-up bracket welded into a '73 for a 2.3T conversion. So, don't use that as a guide for placement.
Quote from: Wittsend on March 11, 2019, 08:41:27 PM
Actually that was "The Whistler." I just provided the dimensions.
Wrong twice in one day  :-[
Don't tell the wife !
Thanks, all.
Quote from: Reeves1 on March 11, 2019, 03:14:40 PM
Wittsend is right : design is very important.
Quote from: russosborne on March 11, 2019, 06:51:33 AM
Ah,
1/8th is 0.125.
1/4 is 0.250.
Opps ! LOL
Was thinking of the metal required for welding to the floor pan, needed to weld the cage to, to meet NHRA spec.
Sorry !
There are two pieces that might be called, "engine frame bracket metal." They are relatively .125.
The Whistler
I will pose this argument! It is not just the thickness that is where the strength comes from it is also the shape! I have put over 600 Hp. on the ground through stock Pinto frame and engine mounts! With no problems on frame mounts and modifications on engine mounts. They hold up fine. This is with a 4 banger mind you. As for material thickness 0.125 is fine a decent design you will never have problems! If you can't design a proper mount use 0.250 thick material. Also think  about this how thick is the material it is bolted or welded to? Which is one more reason why you were told 0.125 is fine.
Turbo is a way of life
1/8th inch is light.
.125 min (1/4") with gussets - this will stand time test & prevent any forward / backward movement.
Thanks.
I am going to be making frame mounts for a 351W swap and 1/8th was recommended. Was hoping I could go smaller, but probably best to stick with that.
The Whistler
I think it is about 0.090 thick close to 1/8 in thick. It is plenty strong!
