Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 10/24/2019 01:45 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 05/24/2020 08:19 am
Built 2.0
Date: 10/07/2018 05:27 pm
Date: 06/19/2018 03:58 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 11/05/2016 09:03 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
  • Online today: 1,106
  • Guests: 123
  • Total: 123
ignition issue
Started by james judkins, January 22, 2019, 04:57:59 PM
james judkins
LongTimeFordMan
Btw..  a prudent safety measure in the meanwhile is to not tighten the negative batt terminal, just sort of jam it onto the battery post so it makes contact but is loose enough to allow you to disconnect it if necessary
james judkins
thanks guys! I will try it!
Jim
LongTimeFordMan
Ditto on the relay..
I had one stick on my 1988 e350 motorhome... completely fried the started before I could get the battery cable disconnected
A quick check is to whack the starter relay on the fender well with a.mallet when it happens. They have a tendency to stick when they are going bad.
Or just replace it, but get a Motorcraft brand if/when you do.
james judkins
Hi everyone, I have a 1972 Pinto Runabout, my igniotn sticks when I try to start my car, the starter continues to engage when key is in the run position,can someone help!
thanks
Jim
