Racing seats
Date: 10/24/2019 09:41 pm
Date: 10/28/2018 08:45 am
Date: 03/17/2019 03:57 am
Date: 01/28/2019 05:15 pm
Date: 02/18/2017 04:47 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 08/20/2017 01:34 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
  • Online today: 1,166
  • Guests: 66
  • Total: 66
Stock oil sending unit help
Started by Crazy Lacy, January 12, 2019, 06:17:13 PM
johnny99
Friend if you don't want to use mechanical oil pressure DON'T they can get messy, if you need a pressure bulb (gauge), or unit (idiot light) I have several, or if you are considering a transformation, I have the 3 gauge cluster, and Tach/Odo if interested......
Johnny
I misunderstood what your concern was.  I have used both copper/nylon tubing to oil pressure gauges with no leaks.  But I have black carpet and a drop or two would not show up.  I have read some people using AN type armored lines in fear of a line burst spraying hot oil.  To avoid oil inside the passenger area, you could use a electric gauge.  I like using both the light to attract attention and a gauge to diagnose what is going on.
Crazy Lacy
I got pressure gauge with the copper oil line, but was thinking to just use the stock light set up. And just hook up the copper line pressure gauge to check pressure once in a while. I always worry about leaks on my carpet  :-\
Join my - Pinto Ford USA - on Face Book.
William "Crazy Lacy" Furmage
Original Vans BMX Freestyle Pioneer 1982
For 71-73 Pinto's, both the engine oil pressure and temperature sensors are connected to that instrument cluster light bulb.  The light bulb is lit by either senor creating a ground.  So the dangling oil pressure senor wire should not light the bulb but if the temperature senor is still connected, it might be the culprit (if there is no short).
Crazy Lacy
I was wondering if the oil sending unit wire is not hooked up to the gauge on the eng block,
Does the light on the dash gauge just won't light with the wire dangling.?
