Date: 02/14/2018 01:34 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 02/08/2018 02:26 pm
Date: 05/24/2020 08:19 am
Brake rotors
Date: 03/24/2017 09:02 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 08/13/2017 02:01 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
  • Total Topics: 16,268
  • Online today: 620
  • Guests: 495
  • Total: 495
converting from power brakes to manual on a 79, what is needed?
Started by russosborne, October 16, 2018, 05:31:47 AM
The 74 manual setup will not work , you will see the clutch cables come out in a different spot , and the brackets are from the early 71 up to early 75 , then they changed , the booster overhaul if they have a shop nearby runs 75 to a tad over 100, last one I had done was $60 , that was ten years ago , still works like new , if you can find someone near you that has one with power brakes and drive it , then make your choice, it's a must have if your going to stuff a larger engine in it and need help to stop the beast ,
Any recommendations for getting the booster redone? One place I saw through one of the online stores was about the same price as a rebuilt one plus shipping.
And would a 74 manual setup work for the 79? I do have the 74, and both cars are manual trans.
Thanks,
To change over to non power brakes you have to have a donor car , there is a plate on the firewall that has to be added , and the brake peddle is different , but keep the power brakes , all mine have them , the booster can be over hauled cheep , plus side it you can take it to the parts store and see if a all wheel disk brake master cylinder will fit it of a newer ford , with the stock power brakes on mine they will lock up the tires if hit them to hard , I let a friend of mine drive my pinto , his pinto did not have power brakes or power steering, everything was fine untel the first stop sign 😳
Specifically do I have to swap pedals or anything in that area?
I don't know if I want to keep the power, and I imagine the booster is bad after all these years.
I will be changing master cylinders either way since I am going with 4 wheel disk brakes.
Thanks,
Russ.
P.S.
anyone else tired of my asking all these questions? ::) :o
