Bell housing
Date: 08/23/2017 05:41 am
Date: 02/18/2017 04:47 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 10/27/2018 03:30 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
  • Online today: 178
  • Guests: 136
  • Total: 136
New member with Project
Started by wrastu, September 26, 2018, 04:16:54 AM
71v8Pinto
Nice work, Sir! Looking great so far.
71v8Pinto
wrastu
For what it's worth, I made a blog type page with pics of projects (bikes and cars) of mine and some of my co-conspirators.
wtfdyb.com aka: WTFDYB Consortium
Duty - Honor - Country - not just a catchy phrase, it's a way of life.
wrastu
Made some air filter bases and tops for the tunnel ram and carbs
wrastu
wrastu
wrastu
Added a cheapo gilmer drive for the alt and water pump.
Bought some vinyl lettering, will get some pics of that now that the board is back up.
Scored a great deal on an Offy 360 turbo thrust tunnel ram, setting up a couple QFT 450's for it, making my linkage and planning the fuel lines for also.
Picked up a Trick Flow Stage 2 cam, some hyd rollers, next gonna get some new alum heads, and thinking real hard about either 3+1 toploader imposter or maybe a T5 or WCT5.
Put some tunes in a couple weeks ago, had to do the 70/80's 6x9's across the rear package tray, added an amp and a sub.
Picked up a stock hood, gonna need to put a scoop on it for the tunnel ram and didn't want to try and adapt the current fiberglass hood in case I go back to a single 4bbl, and a glass hood with a molded in scoop is over 600 delivered.
wrastu
Well it cooling system was having a hard time keeping up so it all came off, but before hand I bought a high volume pump, aluminum radiator, and took it all apart. During disassembly I found the thermostat bypass tube at the thermostat filled with silicone, half the old thermostat blocked by silicone, and the block coolant passages from the water pump half closed off with silicone.
So it is safe to say the previous owner loved applying way too much silicone. But since I had the new parts I went to install them and found the lower drivers side bolt for the block inlet port wouldn't tighten up. D*mn stripped bolt hole. So off comes the timing cover to helicoil or step up to a 3/8 bolt from a 5/16.
What did I find? The bolt had at one time been way over tightened or something had caused the area there to crack all the way through the wall between the coolant passage and the timing chain area. It was smothered in......SILICONE! After getting it all cleaned up it was clear that the chunk of block could come loose and fall in to the timing gear drive, it was still attached but clearly a problem, the chunk was about 2/3 the size of a golf ball.
Well what to do? New block, take it apart and re-use the parts? Another engine?
NAW, I remembered I had one stick of Certanium 707 from years ago. (Used it for welding Hastelloy C276 and 316 Stainless together) Took the grinder and notched it after knocking off the Arc welding flux on the rod, and used my TIG to weld it up after pre-heating the block as much as I could. Used a grinding disc to smooth it down as best as I could, used a carbide 4 flute angled chamfer bit in a drill to flare the bolt hole and took a little longer bolt, turned the head off and tapped it in the hole and welded around the bolt in the chamfer to make it a stud now.
The thought is if the piece cracks or breaks off there will be leak but the chunk won't end up the timing gear drive as it will be attached to the stud. The weld should hold as it only holds the timing cover and water pump on, it ain't pretty, but now I get to silicone up that area.
I didn't have any proper cast iron rod but have used Certanium 707 in the past on cast iron and never had  problem, and the area will heat and cool uniformly with rest of the block, and isn't exposed to cool air like a manifold would be. Guess this winters project is a to build another engine.
Will post some pics after it is all together, my welding sucks on this repair and I ain't showing it off.
wrastu
This little car just keeps surprising me. Took off the valve covers to clean them up some and when removed look what I found!
wrastu
Well mostly done for the winter mods, have a smaller carb on the way, need to paint the hood yet, and front end alignment tomorrow hopefully.
But the Old Pony got to got out and stretch her legs around the block and test out the manual valve body.
Still needs a bath, but here she is for this season anyway.
wrastu
Quote from: pintoman1972 on March 19, 2019, 09:41:42 PM
Mileage, what mileage?
When I get asked about millage I tell them I GET 1000 SMILES PER MILE!
Sometimes it is how many traffic violations per tank full ::)
Thanks again.
Appreciate the help.
wrastu
Quote from: russosborne on March 19, 2019, 11:04:32 PM
Thanks. Sounds simple enough that even I can do it.
Hint/Tip: the nicer (shinier) finish you have before you start jeweling more prismatic the results will be, and a light touch is all that is needed. Test pieces are a good idea.
Stu
Quote from: wrastu on January 26, 2019, 10:03:37 AM
Nothing fancy as tools go, a 3M scotchbrite circular disc held in a cheap drill press spun about 500-1500 rpm pressed flat to the surface, I use WD-40 as a wetting/lubricant and free hand away, I use a sharpie to mark some rough lines to follow and over lap each circle to cover the entire surface. Easy peasy.
pintoman1972
wrastu
Had to make a coolant overflow/reserve tank, just because I could.
wrastu
Got my home adapted ford floor shifter in, it has reverse lock out and uses the detents from n to 3rd gear, reverse pattern manual valve body now.
Friend of mine made a factory looking cover out of some aluminum scrap, looks enough like the original, but just enough that you look twice and realize it isn't. Had to grind new shift notches, should work ok for now.
wrastu
Too cheap to buy a deep pan for the trans, so I made an extension and some line holders for the fuel and trans cooling lines.
wrastu
Well finally got the door panels mounted.
wrastu
Spent the evening working on converting my stock automatic floor shifter to something that will work better with the manual reverse pattern.
I wanted to keep the factory type linkage for the trans instead of changing to a cable that would be real close to the header on the drivers side, and new shifters cost a bundle, so I modified mine to the point I am happy with the way it turned out.
Till have yet to make the pull up lever attachment for the release bar and find a shift knob I like.
wrastu
Bumpers back from powder coat, first time they were a little to light of a shade of gray, this time they are as close as they are gonna be. My powder coat guy is real good with his want to please the customer, he did the bumpers over no charge, and built it up a bit to hide some of the pitting, it will be fine for a driver.
Put my home made air dam on the front and that's about it for the front.....time to finish the rear bumper.
wrastu
Thanks all for the compliments and encouragement.
Got the C4 valve body out, it is going to Montana to converted to reverse pattern manual shift. Getting new output yoke seal and new u-joints also.
Was replacing the windshield seal/rubber the other day using the string method and got down to the last 3 inches and CRACK. Gonna have a local guy who does a lot of custom and hot rod glass order me a new one and put it in. The other was hazing up on the corners pretty bad anyway, and had permanent marks in the glass from the windshield wipers anyway.
Gonna slow a bit for a couple to three weeks, Wife is having surgery and I will be playing nurse to her.
Stu
one2.34me
wrastu
My little pony got new rear booties today.
wrastu
Quote from: russosborne on January 26, 2019, 02:49:58 AM
Nice.
I've thought about using aluminum, but I would have to just go with plain, no fancy tools.
Nice.
wrastu
Snowing like crazy here, and I spent the day helping a friend add OSB to the inner walls of his shop, came home and decided to do the door panels I made the other day.
Got a sheet of AL for various things, decided not to use the destroyed / worn out door panels, so I made some and presto.
wrastu
Bumpers, front and rear, not fitted spaced/shimmed perfectly, will fit them better after powder coat, did paint with some gray so I can visualize what they will look like powder coated, pushed in, trimmed, filled.
Not perfect but they will do.
wrastu
Quote from: russosborne on January 09, 2019, 12:33:56 AM
Thanks.
I am trying to think of a way to route the fill hose without being in the car. Not sure I can lower the cell enough.
Thinking I might have to have a raised floor.
I have to pass emissions here also. They check the fuel cap for vacuum or some such thing.
I don't have to pass smog here, and the cap I picked does seal and is not vented, the tank has a vent / tip over valve that has to be run to a location higher than the filler neck opening.
The filler hose will run thru the trunk, and I am going to add an aluminum panel over the opening at the back of the rear seat, and an aluminum package shelf cover, so if hit from the rear the gas and fumes shouldn't enter the passenger compartment very easily.
Thanks.
