Date: 05/13/2021 05:29 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 07/10/2016 10:17 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Seeking parts
Date: 10/18/2020 10:35 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
  • Online today: 2,670
  • Guests: 545
  • Total: 545
How do you repair a frame that's rusted....missing
Started by xonknor, May 07, 2018, 08:38:52 PM
I made my own floor raplacement panel but thankfully I didn't have to replace the rail too.  If after you have removed the rail you can flatten it (may require cutting on formed corners) you can make a template on cardboard. You may be forced to only make something "similar" but I'd think if you follow the general principles you should be OK. As with all mods, "Do at your own risk."
Below is an image of the replacement panel. I put dimples in to strengthen the flat metal. I simply used a larger socket on the bottom and a smaller one up top. If you notice some are missing. Ahh..., yea, when it all slips, you smash your finger..., you say "enough is enough." None of it is pretty, but it is all under carpet. The two parallel rows are where the floor was plug welded to the frame rail.
DBSS1234
Having restored several very rusty vintage Mustangs over the years I can say, yes it can be fixed BUT. You need to make sure the new part is welded to good metal and has good welds securing it. You will need to have repair panels made by a local sheet metal shop of fab them yourself since Pinto repair panels are not available (you can also use rust free used panels if you can find some). If you have the panels made or you make them yourself use metal the same thickness or a little thicker than stock, do not go lighter we are talking frame here! Any areas where you butt weld be sure to include a "backing plate" behind the weld. Also take as many measurements as you can before you cut out the rusted metal and use these measurements to locate the new metal. Not fun but doable.  ;)
xonknor
I just bought a '79 Pinto and after inspection noticed that the frame was pretty much gone on the passengers side. Rusted out totally. Can one repair this by welding new material in? Or can you buy a new frame rail?
Thanks xonknor
