Date: 07/04/2017 03:26 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 12/30/2022 01:30 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 08/17/2022 06:27 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
  • Online today: 306
  • Guests: 220
  • Total: 220
Epoxy for intake manifold
Started by LongTimeFordMan, April 17, 2018, 05:54:06 PM
LongTimeFordMan
Hi all.. my custom i take manifold for 2 SU carburetors is almost finished but i need to do some filling around the mating surfaces on the intake ports.  The welds are a bit crude and I have had the mating surfaces surfaced on a head sander but there are some small areas that still need filled. And i also need to smooth and contour the interrior of the manifold ports  match the ports to the ports on the head.
I have read that some folks have used "epoxy" to partially fill the intake ports on a 2.0 and was wondering if any of you have had experience using JB Weld on an intake manifold.
I was contemplating using the "high temp" 500 F degree rated version and was wondering if it would hold up under the heat considering the head shouldnt get above 300 F
Any suggestions?
