Pinto for sale
Date: 04/19/2017 10:15 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 01/19/2020 09:06 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 04/12/2017 06:57 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 03/17/2019 10:15 pm
  • Online today: 1,106
  • Guests: 284
  • Total: 284
73 2.0 head specs
Started by LongTimeFordMan, October 06, 2017, 02:46:49 AM
LongTimeFordMan
Thanks...
I have 3 heads total, one good, the others not good...  measured them all and the one with the biggest gap between the spark plug hole and the lower surface measures 95, its cracked and no good but i think its stock..
I guess the stock height must be 94.8-95. That will get me close enough to judge how much the good head has  been cut..
72DutchWagon
look at: http://www.turbosport.co.uk/showthread.php?t=157988
94,9mm = 3 47/64 inch, I've seen 94,8 and 95 mentioned elsewhere, so pretty much in the ballpark?
LongTimeFordMan
Does anyone know the height (thickness from block mating surface to cam cover mating surface ) of a stock, unmilled 2.0 cylinder head? I'm having a valve job done on a used head of unknown history and was wondering how much I can take off, not knowing if it has already been milled.
Btw, I know that milling the head can affect the cam timing and am using a custom cam and adjustable cam pulley .. so ill just be adjusting the cam for best performance.
Im also using stock 8.1:1 pistons so valve clearance wont be a problem.
