Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 10/24/2019 01:45 pm
Date: 10/25/2019 04:05 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 10/27/2018 03:30 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 03/06/2017 01:24 am
Date: 09/10/2018 10:41 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
  • Online today: 1,106
  • Guests: 91
  • Total: 91
Ujoint installation
Started by Jdm071755, August 16, 2017, 08:26:38 AM
After you remove the rag joint, the shaft will slide down and out as it fits inside a even larger shaft shaped housing under the dash. May need to help it slide out (bfh). Not hard to do and much easyer than doing it in the car.
Jdm071755
Quote from: dick1172762 on August 17, 2017, 09:48:07 AM
No cutting but a very small amount of grinding maybe.
Thanks for you help. One last thing do you have any tips on taking out the shaft?
Joe
Jdm071755
Quote from: dick1172762 on August 16, 2017, 12:54:14 PM
I've done several with no problem's. If you buy a u-joint, make sure its one that has a thru bolt on each end to tighten it onto the shafts. Otherwise you could end up with one that needs to be welded to the shaft. You'll love the way the steering feels afterwards. Got my u-joint off of E-gay. Sorry but no pictures.
Thanks.
Is there any cutting involved?
Joe
Jdm071755
Has anyone removed the rag joint and put in a u-joint?  If you have can you please pot some pictures
Thanks
Joe
