1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 02/27/2017 10:10 pm
Date: 04/20/2017 10:10 am
Date: 01/10/2022 03:41 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Date: 08/08/2018 12:26 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 09/01/2017 11:58 am
  • Total Topics: 16,268
  • Online today: 620
  • Guests: 491
  • Total: 491
Manual to automatic questions
Started by vikingsandpintos, August 13, 2017, 11:07:42 AM
blink77
Make sure to remove pilot bearing!!!!!
Sounds like you already know what you need. The drive shaft is different than a stick shift. You may be able to use an automatic drive shaft from a wagon, but it may need shorting some. And if you change yokes to an automatic yoke, the stock drive shaft may work. I've done this swap, but from an automatic to a stick shift. Cross member, spedo cable, etc all fit just fine, but the spedo gear in the tranie may need changing due to its number of teeth being different.
vikingsandpintos
I have a 79 Pinto with the 2.3 and 4 speed manual trans. I want to switch it to an automatic. I am getting too old to shift all the time! lol  I took it to a cruise last night, and it is a pain in really slow stop and go cruise traffic.
It is not really a daily driver, but part of that is because I have grown to dislike the clutch. I think if I put an auto in it, I would be more prone to drive it more often.
What all do I need to change to the auto? I know the normal such as the flywheel, and shifter, ect. And I'll need a trans cooler and lines, I don't think my rad has a cooler in it so would prob just add a separate cooler.  I have a couple of Pinto wagons around the same year at storage, I think one had a good trans. Will my current driveshaft work? I didn't know if the yoke and trans length were the same. I assume the wagon one is prob longer than my 2 door? Speedo hook up the same? Trans crossmember? Or is there anything else to watch for that I haven't thought of? Thanks!
