Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 09/21/2018 11:35 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
looking for parts
Date: 06/19/2020 02:32 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 04/28/2018 04:12 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
  • Online today: 1,106
  • Guests: 90
  • Total: 90
wires off alternator keep melting/burning up
Started by nanowagon, August 08, 2017, 11:54:04 AM
You might try running a ground wire off of the alternator case if all else fail's.
The alternator wiring could care less about car size because the wiring for the alternator is the same in all Pintos. The size engine and AC only count in picking the power out putt of the alternator, NOT the wiring. All alternators made today in the USofA are three (3) wires and one wire (1). Or so I'm told.
nanowagon
its a 77 w/ a 2.8 v6 with a/c if that info helps at all
If you have a white and a green wires plus a stud/nut, the green wire goes to the coil, the white wire goes to a 12 volt source, or you can attach it to the stud/nut along with the large wire that goes your 12 volt source. This is what I've done to my own cars and is just the way I did it.
Can you provide more info on the car? Year, model, engine?
nanowagon
hey guys, installed a new alternator/voltage regulator and my white wire off the alternator keeps melting, the orange one looks a little burnt too but cant tell if its just cause the heat from the white one or not, I don't know much about wiring, what does this wire go to?
