2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 09/22/2020 11:33 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 12/04/2018 07:40 pm
door sills
Date: 03/14/2020 03:20 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 10/24/2019 01:43 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
  • Online today: 449
  • Guests: 200
  • Total: 200
Pinto 2.3 oil
Started by sedandelivery, July 10, 2017, 01:20:58 PM
Quote from: dick1172762 on July 16, 2017, 10:55:44 AM
I've owned 16 Pintos since 1972, and all up to this day, used over the counter major brands of oil. (Wall Mart oil too). I have NEVER lost even one cam in this time. In 1974/75 the Ford 2300 cams were junk if you ran the oil until it turned to tar. I've always changed mine at 3000 miles. On high mile car I would add STP. I found when I was just out of school to always try to find out what kind of oil had been used in the car before and keep on using it. 2300 Cams are made with a profile very much like a roller cam and as such wear like a roller cam. Keep the oil clean and NO day glow Fram filters and you'll be just fine. This post is just what I do. Use your brain and all will be ok.
That sounds like logical advice to me!  Thanks, Dick!
Dwayne :)
I've owned 16 Pintos since 1972, and all up to this day, used over the counter major brands of oil. (Wall Mart oil too). I have NEVER lost even one cam in this time. In 1974/75 the Ford 2300 cams were junk if you ran the oil until it turned to tar. I've always changed mine at 3000 miles. On high mile car I would add STP. I found when I was just out of school to always try to find out what kind of oil had been used in the car before and keep on using it. 2300 Cams are made with a profile very much like a roller cam and as such wear like a roller cam. Keep the oil clean and NO day glow orange Fram filters and you'll be just fine. This post is just what I do. Use your brain and all will be ok.
sedandelivery
We use Rotella in the Railroad car generator and the backhoe, what oil today has enough zinc in it? My Bobcat runs so well, I want to keep it that way. Thank you for the reply.
10w-30w with added zinc or you will wipe your cam lobes and or distributor gear. Note most if not all modern engine oils do not have enough zinc or ZDDP due to both closer tolerances and smog laws .. You have far fewer choices about oil.
And no the diesel oil called Rotella used to good however these days no! For the same reasons....
10/30 of any major brand is fine. If you can, ask who ever you got it from what he used.
sedandelivery
What type oil works the best in a 1980 2.3 litre engine? I am guessing 10/30 or what works best?
