Seeking parts
Date: 10/18/2020 10:35 am
74 hood
Date: 07/03/2017 03:46 pm
80 pinto original
Date: 08/04/2019 10:45 am
Date: 02/27/2017 10:10 pm
Date: 10/03/2018 10:46 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 03/25/2019 09:02 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
  • Online today: 1,166
  • Guests: 1099
  • Total: 1099
1971 Pinto help!
Started by Rawdawg510, July 06, 2017, 01:42:11 PM
Rawdawg510
I would have to check if it has 2 or 3 lines. So why cant I use the vent as a return line? that was not answered in the thread?
1965 Ford falcon
1971 Ford Maverick
1971 Ford Pinto
2017 Ford Fusion Sport
1) If stock, I believe the small line going to the tank is the vent.  Later Pinto's had a return line from the engine mounted fuel pump (so three lines to the tank).  This thread from the FAQ section discusses several options.
http://www.fordpinto.com/pinto-faq/fastest-best-way-to-create-return-line-for-gas-tank-efi-setup/
2) If the EGR is working and not in the way, it has benefits from what I have read.  If removed, the car will run okay but will generate a trouble code when tested, if that is a concern.
3) My 87TC 2.3 has the front dip stick hole drilled and plugged, suspect the 88TC would be the same.  You would have to visually verify this with your block.  If missing, it can be drilled.
As you mentioned, there are several threads documenting 2.3 turbo installs.  Wittsend made a two part write up that is a good reference.
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-1/msg76893/#msg76893
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-2/msg76894/#msg76894
Rawdawg510
hello guys I am fairly new to this Forum, still looking at any threads for this swap but I still have some questions about the swap. I'm 23 and really look forward to this project.
I have a 2.3t/t5 out of a turbo coupe 87 or 88. I have everything from the air cleaner to computer (LA3). I will be going with a stinger wire harness to save a lot of time with wiring as that is not my strong point. my pinto actually has a 2.3 now which is weird as I know 71's didn't come with them.
so I my questions are.
1) for the EFI conversion will my gas tank work? I went down and looked at the tank and I think it has a return line, would I be able to hook that up to the return on the fuel rails?
2) EGR smog delete? my car does not require smog so I would like to trash all of this. I have been reading about the PIMP computer but really out of my price range for now. will this affect the car from running properly if I just delete the system.
3) as my car already has a 2.3 I don't have to worry about engine mounts but where would I put the dip stick when I convert it to the front sump oil pan. I remember reading that the 86 engines have a plugged hole in the front of the block is this the case for 87/88's?
I have the clutch pedal assembly/cable/tranny crossmember out of a 4 speed car I found at the junk yard I think it was a 71-73. I also have a mustang rear-end I will swap in later. if there is any thing I missed, any information you guys need, please let me know if this is all repetitive I am sorry I know there is a lot of threads on this swap but I have tried to look these up on my own and not bother you guys. there is just to many threads I cant read them all lol.
1965 Ford falcon
1971 Ford Maverick
1971 Ford Pinto
