Date: 09/10/2018 10:41 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 10/31/2018 12:00 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 07/13/2018 02:21 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Date: 12/24/2016 04:13 pm
  • Online today: 506
  • Guests: 222
  • Total: 222
71 pinto runabout 1/2 window hatch
Started by oldschool787, June 21, 2017, 11:41:30 AM
oldschool787
so im testing the water to see what kind of offers I can get on my pinto. I drive it rarely I keep it for a conversion piece. its a 1971. it s the runabout model small window hatch. paint and inside is rough from setting in the az sun for 8 years straight without moving. only surface rust. all stock motor and trans rebuilt and gone through in jan 2013. everything works.
motor is a 2.0 rebuilt using 90 per cent NOS parts and for the non FORD fans like me the 2.0 was a German Ford motor which is way better than the USA Ford crap they make now.
at the time of rebuild:
I found it was bored 30 over
new rings
10/10 rod and main bearings
new timing belt and tensioner plus extra
new alternator
new voltage regulator
new starter
rebuilt head
new cam
new lifters
rebuilt distributor with pertronix ignition kit
clean and flushed radiator
timing belt with tensioner pully
I do have the timing belt cover
trans is the factory 4 speed
all new seals
gears and disc inspected and looked to be good
new mounts
new u joints
the suspension can use attention due to sitting for 8 years in a field
rack and pinion could use rebuilt
could use new shocks
has new tie rods, upper control arm bushings, upper ball joints and brakes on the front
inside:
chevy front seats :(
new headlight switch
new high/low beam switch
new break light switch
sunpro tech/oil pressure/amp/ and coolant gauge trying to still keeps that 70s look
all new dash lights
am/fm/cd (still have the factory uncut radio mount too)
dash is cracked
carpet shoot
headliner is gone but still have the rods for it
rubber seals are sun beat
I do have uncut kick panels
outside:
13in 5 spoke 70s rims which are Shelby 2 rims
4 brand new tires as of 6-14-17
I have 4 hub caps but only one steel rims
all glass is good no cracks and is factory
no major dents just little hail sizes one mostly in the fenders
paint is sun baked
all lights work including dome and back up lights
setup for tow bar which I have
this car runs and drives just as it sets. I'm still doing work to it here and there. I have driven it to flagstaff and California many times less then 4000 or miles on it since ive did the motor work. don't let the looks fool you. make me a reasonable cash offer or trade looking at pre 67 vw in running driving shape, 80 or older chevy truck, jeep xj or willys, 14-20ft enclosed trailer, 86 or newer 25ft or smaller travel trailer or motor home, pre 72 hearse or what do you got
car I located in kingman az please leave a message if you call as I cant always answer my phone may be willing to meet up to 250miles if its a cash buyer not meeting for a trade
More Information
I might own one FORD but, I own a Chevy and a trailer.
