Date: 02/26/2017 03:22 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
71-73 sway bar
Date: 06/12/2021 10:12 am
Pinto Watch
Date: 06/22/2019 07:16 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 11/08/2020 02:10 pm
  • Online today: 344
  • Guests: 196
  • Total: 196
1980 PINTO for sale
Started by dick1172762, June 19, 2017, 02:51:48 PM
1980 PINTO for sale
Due to my health going south, I need to sell my pride and joy 80 Pinto coupe. This is a rust free south Texas car with clear title, and the following parts / work done on the car during the 5 years I have owned it. Ball joints and tie rod ends NEW / Kyb gas shocks NEW / rack and pinion NEW / 13 X 7 mag wheels USED / 205-60-13 Federal tires NEW / Door seals and wipes NEW / brake rotors and calipers NEW / AN braded brake lines NEW / Carpet NEW / engine crank and rod bearings plus seals NEW / mustang cast iron header NEW / 3.55 ratio 8 inch rear end NEW / dash cap NEW / Ranger roller cam and rocker arms USED / comp cam lifters NEW / turbo rocker arm cover USED / clutch pressure plate throw out bearing NEW / clutch throw out cable NEW / drive shaft u joints NEW / heater core and hoses NEW / Adco front and rear sway bars USED / motor mounts NEW / rear mounted battery NEW / hi pressure fuel pump with regulater NEW / Ranger late model master cylinder NEW / remount oil filter with oil cooler NEW / water pump NEW /  timing belt NEW / distributor NEW / ford E-coil NEW / plug wires NEW / plus more I'm sure. Crack in windshield / paint (orange) needs help. Drivers seat bottom needs work / rest are ok. Will not ship! Bring a trailer as front end will need alignment. NO AC / Just roll down windows and go 60.
More Information
