Date: 01/24/2021 07:54 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 02/14/2018 01:34 am
Date: 07/30/2020 11:45 am
Date: 02/08/2018 02:26 pm
Date: 08/09/2018 07:49 am
1979 pinto
Date: 04/19/2018 02:02 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 07/08/2022 11:51 pm
  • Online today: 449
  • Guests: 209
  • Total: 209
A/C combination valve
Started by warhead2, June 09, 2017, 05:50:49 PM
warhead2
Im restoring this 77 cruising wagon. Was looking in the shop manual and couldn't find it so thought it was missing but you cleared that up thanks.
Sent from my SAMSUNG-SM-G930A using Tapatalk
The dealer installed A/C does not have the combination valve , the unit that used this system has a expansion valve built on to the whole assembly that goes in/under the dash , you can try vintage air , they make some nice small units that will fit in the dash , or find a wrecked pinto nearby that has the whole factory set up and swap it over , done it a few times , take a whole weekend
warhead2
Thank you for the reply. The engine is original. I figured it was a dealer install but was unsure because the reciver dryer is by the window washer fluid tank. So if a dealer did install it does it have the combination valve?  The hose's are by the heater hose's
From the photos they are two different hook ups , one the valve and hoses in the photo is for a factory A/C ,  which should come out were the fan motor that is sticking out the fire wall , the compresser you have in the photo is a dealer installed A/C unit , (see hose clamps ) you will find two holes in the fire wall someplace , unless somebody put that engine from another car and left that compressor on it ,  "note " factory A/C cars have the blower motor inside the car ,
warhead2
Where is the A/C combination valve on 77 cruising wagon is it in the engine bay or inside under the dash? Also if in the engine bay does anyone have it mounted in a different spot? If so post a picture. 2nd pic Dont know if mine is missing or I just missed it because it was was mounted elsewhere.
