postal pinto
Date: 06/03/2020 09:31 am
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Date: 04/06/2017 12:13 am
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 03/06/2017 01:19 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 10/24/2019 01:45 pm
Date: 08/09/2018 07:49 am
  • Online today: 1,044
  • Guests: 1026
  • Total: 1026
How to remove switch
Started by ldj1002, May 05, 2017, 07:57:20 AM
robertwwithee
Glad to have been able to assist.
ldj1002
Quote from: ldj1002 on May 05, 2017, 03:03:50 PM
Thanks, I'll try that.
I found it. Had no idea the ignition switch was way down there and and a long rod from the key lock worked it. Thought it was right there at the end of the key lock.
ldj1002
Quote from: robertwwithee on May 05, 2017, 02:52:57 PM
Key switch has no electrical parts attached to it.  Typo
robertwwithee
robertwwithee
Ok, ignition tumbler has a pin that needs to pushed and key has to be in the on position.  There are electrical parts on it though, electrical is down on column at least on early cars.  Look under dash on top of column for a rod that attaches to switch assy.  That is a failure point and is probably ur problem.
ldj1002
Quote from: robertwwithee on May 05, 2017, 11:08:15 AM
Remove steering wheel and you will see the turn signal switch.  I believe there's 3 Phillips that holds it in place.  Unscrew lever and disconnect wiring running down column.  Whole switch should come out.
The whole switch, is that the turn signal or ignition. The ignition switch is what I want to remove or get to. I don't think the turn signal switch is is my problem.
robertwwithee
ldj1002
On 79 Pinto how do you remove the key lock and how to remove the switch? My turn signals work some time and some time don't. When they don't work there is no power to the fuse. Makes me think it needs contacts cleaned or at least sprayed with a contact cleaner. I need to get it all apart to get to it and find out why.
