2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 08/01/2018 01:27 pm
Date: 03/16/2017 10:00 pm
Date: 05/22/2018 02:27 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 12/15/2018 02:21 am
  • Online today: 1,044
  • Guests: 940
  • Total: 940
Part number
Started by Jdm071755, May 02, 2017, 04:27:47 PM
Jdm071755
Quote from: TIGGER on May 03, 2017, 02:50:47 PM
Sorry, I forgot last night.  You know, your valance does not look too bad to me.  It looks to be in the same shape as the one I have currently on my car.  Mine too is missing the lower tabs.  I took some scrap sheet metal, and cut some pieces about the same width as the lower tabs.  I drilled a hole for the bolt and I overlapped the sheet metal over the remaining piece of the plastic tab.  Basically sandwiching it between the sheet metal and the core support.  Hopefully that makes sense.  I have been running mine that way for years with no issues.  My son has a baseball game tonight but I will try and remember to get you that p/n after.
Thanks for the advice it's very helpful
Joe
Jdm071755
Quote from: TIGGER on May 02, 2017, 07:58:16 PM
If I remember I will post it when I get home.   Unfortunately these rarely come up NOS.  You are better off seeing if MAP351 still makes his reproduction from Fiberglass.
I sent a PM to MAP351. Not sure if he will answer. He has been inactive for a while.
Joe
Jdm071755
Thanks
Joe
Jdm071755
Need oem part number for this part.  Is it called a Valance?
Joe
