Date: 01/30/2017 01:48 pm
1979 pinto
Date: 04/19/2018 02:02 am
Date: 01/04/2017 04:07 am
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 04/10/2017 07:30 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
Date: 02/04/2018 08:26 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
  • Online today: 134
  • Guests: 127
  • Total: 127
302 into a 77... have a trans question
Started by pgccp, April 15, 2017, 03:06:44 PM
found that early 70s case fill (car only )C-4 are just small enough ,302  mustang two C-4  was the smallest ,and also the hardest to find , even the C-6 is out because of its huge , I also tried to install a 700R4 because it was a tad shorter than the A4LD transmission but the right side of it hit the headers and also the body , even after all the time making the adapter to fit the 2.8 and flywheel hook up I did not want to beat up, bend, slice and dice the body to make it fit , if it would have been just and small bend or dent I would have used it , sold to a guy with a ford explorer , Installed The A4LD , qq2ofus plan is very true , plan each step as a life and death operation , later Blaine
qq2ofus
Beware of the year C4 you use, a Big head bell just will not fit in the tunnel, I have a 77 I am doing a swap on, I ended up buying a BW-RAD 4 Spd (also Have a T-5) and by using the RAD it was not such a fight, I also have a set of Hooker headers (designed in 1980 for Pinto Swap) did not use them because of lack of space between the frames and engine, so I used the 77 Mustang II manifolds (perfect fit), right now I am in a holding pattern waiting the arrival of a second left Upper Motor Mount, and Trans Mount, another tip. to gain an added 1/2" clearance at the top of the trans tunnel, You can use a body wedge and sledge to drive the firewall in 1/2" without breaking anything (wedge gives it a factory indent look), You will also need the driveshaft yoke from whatever vehicle you use the Tranny from... you must use caution and discretion at each fit, or it can end up costing you financially, so try to stay ahead of your build and plan each step...
John
I'm a member of the Pinto club, driving pintos is what I love  I don't like ol' pickup trucks, I'm a member of the Pinto Club
I'd assume so.  After all it is just a means to get ATF into the trans.  HOWEVER, with the original tub and stick in place I'd measure the the marking points (low/high) in relation to the pan gasket surface on the trans case.  That way you can adjust the new stick depth accordingly.  I did similar when I put a 700R4 in a Studebaker. Because of firewall clearance issues I had to make a dipstick tube with electrical conduit save for the original ends which were silver soldered on.
pgccp
I know a c4 with a case fill tube is the way to go.
My son-in law has a c4 pan fill can I use the pan fill
with a after market flexable dip stick tube? If available
Thanks Bob
