NOS Sedan decklid
Date: 10/23/2019 11:51 am
74 hood
Date: 07/03/2017 03:46 pm
KYB shocks
Date: 02/08/2017 07:09 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 02/18/2017 05:52 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 06/28/2019 09:14 pm
Date: 08/09/2018 07:49 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
  • Total Topics: 16,268
  • Online today: 354
  • Guests: 169
  • Total: 169
Station wagon leaf springs on a hatchback....
Started by Rob3865, March 18, 2017, 08:58:03 PM
Rob3865
My apologies. I had asked this before. I did a search after I posted this thread and found it. It appears the two springs are not compatible.
By better stance, I mean to give the car a little rake from back to front.
Can you define what you mean by "better stance?"  The reason I ask is that the wagon seems to sit like a hatchback from my perspective. So, it may be that they don't elevate the car any, they just resist (extra) weight - more.  Also you will have to use an extended shackle to (properly) install the spring.  It may be that installing them at the hatchback spacing (if even possible) would elevate the car but I would be careful to look for the spring binding as it seems the swing rate of the shackle would be accelerated.
Rob3865
As the title implies, will wagon leaf springs fit on a hatchback? Mine is a 76 Bobcat MPG Runabout and I want wagon springs for a better stance. I know the springs A and B measurements are a little different, but do they interchange? Thanks.
