Date: 08/03/2018 09:19 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 07/17/2019 05:23 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 05/21/2019 11:50 am
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 11/08/2019 10:01 am
78 hatchback
Date: 03/12/2023 06:50 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
  • Total Topics: 16,268
  • Online today: 354
  • Guests: 173
  • Total: 173
7/8" rubber body plugs?
Started by dholvrsn, March 13, 2017, 09:27:17 PM
There are plenty of various size plugs, including 7/8" at (ford pinto body plugs on E-gay) right now! E-gay should be the first place you look for hard to find pinto parts. I get a kickback for that statement. Tell them I sent you.
72DutchWagon
Steele Rubber supplies several sizes rubber body plugs for Pinto's, did you try their site and do a search on your year, make and model?
Depending on the the plug size/type itself they can total to a rather expensive replacement.  For instance on my Sunbeam Tiger the club has "Trunk Plugs" that are about 6 or 8 plugs.  They cost about $60 for the set because they are a slightly odd size and some people want an "exact" replica of the original..  Even at $3-$4 a piece for generic pugs they can add up when you need a large number of them.  I've resorted to pulling the size I need out of newer cars at Pick Your Part yards. They seem good as new and are a lot cheaper.
Do a search on E-gay at ford pinto nos. If that doesn't work, soak them in gasoline if their not cracked. It'll make them soft again for a while after you remove them from the gas. Long enough to reinstall them. Also take a look at Scott Drake automotive group.com,as all ford should be the same(????)
Does Dorman or somebody like them make replacements? Mine are pretty dry rotted away.
