Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 08/02/2019 04:18 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 07/04/2017 03:26 pm
Date: 09/01/2017 11:58 am
pinto floor mats??
Date: 01/11/2017 07:27 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 09/15/2019 12:28 pm
  • Online today: 1,106
  • Guests: 109
  • Total: 109
Wiring diagram for brake fail switch
Started by LongTimeFordMan, March 10, 2017, 09:18:44 PM
LongTimeFordMan
I found this diagram for the brake fail light switch for a ford on a ford forum
Apparently the circuit is wired from the "run" position on the ignition switch, thru the indicator lamp, then to the switch on the "combination valve"  or proportioning" valve which grounds when there is a pressure difference between front and reat brake circuits.
There is also a connection to the starter relay which causes the light to light when the ign switch is in the "start" position.
