1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 05/18/2020 10:22 pm
Date: 07/04/2022 07:55 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 03/05/2017 03:27 pm
Date: 04/12/2017 08:15 am
  • Online today: 1,106
  • Guests: 85
  • Total: 85
rear windhield heater
Started by cj3b, February 06, 2017, 04:55:08 AM
You might have to check the fusable link , they are a wire connector end that serves as a fuse and a terminal end , it's bolted to the starter solonide post , see if its burned or not hooked up , you will see it go through the firewall by the heater hoses ,
cj3b
Hi Tigger
no the indicator ligth do not ligth and on the conectors of heater i have no voltage ( no matter how the Switch is set ) - i will check the Position of the Relais (i hope i will find them ... lol).
thank you
Dan
I believe the relay is behind the dash above the glove box door?  Does the indicator light stay on when you activate the switch?  If it does you might want to see if you have any voltage at the wires on the heated glass.
cj3b
Hi all
i have some problems with my rear windschield heater who will not work. When i look at the fuses, every fuse is ok, and i got 12V on every fuse. When i activate the heater-switch you will hear a "click" of the relays, but nothing happens. Where is the heater-relais mounted and have someone an idea whats the problem could be?
ps (i got also no power on the horn button - and all fuse are ok.....)
sorry for my bad english, i hope you will understand what i mean...lol
thank you and regards
Dan
