Date: 10/03/2018 02:00 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 07/04/2017 03:26 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
  • Online today: 119
  • Guests: 72
  • Total: 72
78 wagon front shocks
Started by ToniJ1960, January 30, 2017, 05:32:18 PM
Welcome back Tonij. Shocks are so easy a Vega owner could do it. Hardest part is jacking up the car. Put a jack stand under the control arm, directly under the spring, let the car down a little to take the tension off the shock, unbolt the shock, remove it out the bottom. BTW most shocks made today have a 5/16 or 3/8 hex on the upper tip of the shock to hold on while you unbolt the top nut. If your old shocks don't have it, use a vice grip plyers to hold on to the shinny shaft. Reach through the spring to hold with the vice grips. Just remember to not clamp on to the shaft threads. Don't stay gone so long.
kman
Very easily changed, top stud and bolt at the bottom.
KMAN
Don't know about 78 but I changed them on my 74 and it was easy.. Regardless of brand though make sure you get the appropriate shocks for the type driving you do.
ToniJ1960
 Can I change them myself? Anyone recommend particular ones? I might try Gabrielle.
