Pangra wanted
Date: 02/05/2017 01:58 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 12/31/2017 09:03 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 06/18/2018 03:47 pm
Date: 08/26/2018 06:35 pm
Pangra wanted
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
  • Online today: 1,090
  • Guests: 136
  • Total: 136
Fuel Tank
Started by Jdm071755, January 19, 2017, 09:47:06 AM
Jdm071755
Thanks,
After further inspection there are some Hugh cracks in it also. Also there was a pad on top of the tank that's all rotted, Can this be replace with a rubber pad?
Thanks
Joe
Joe
Easy to fix small pin holes on top or bottom with solder. Can be done very easy with a soldering iron. What ever finish Ford put on the tanks, it will solder very well.
Jdm071755
Got the tank out, The top of the tank is rusted and has some small holes in it.
Guess its tank time.
thanks
Joe
Jdm071755
Thanks
I will give it a try
Joe
First clean all around the tube with a scotch pad lubed with some transmission fluid , wipe clean , apply more oil around the tube and seal , remove the screws at the gas cap flange , at the bottom of tube rock the tube back and forth and push in , oil on tube will help tube slide in , Turn tube forward and down pull tube out , if tube flange is on the outside of fender the recall has not been done , make sure tank is empty before you pull tube out , when you put it back together grease seal up and tube also , after your finished wipe off extra grease ,
Jdm071755
I need to drop the fuel tank for cleaning and I am having a hard time removing the Filler Tube are there any tricks?
Thanks
Joe
