Date: 05/22/2018 02:27 pm
Date: 07/30/2018 04:32 pm
Date: 08/22/2018 09:23 am
pintos for sale
Date: 12/11/2018 04:29 pm
Date: 02/03/2018 11:28 am
Date: 09/02/2021 08:21 am
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 1,972
  • Guests: 162
  • Total: 162
TECH TIPS
Started by dick1172762, December 24, 2016, 10:39:00 AM
When I could not pass a smog check, I used to do the following .Turn the idle mixture screw in till the motor starts to run ruff, then back out 1/4 turn, If its still ruff turn it out one more 1/4 turn. Next get two cans of Heat or Heet and put them in your gas  tank. Next remove the air cleaner element from the air cleaner and go for a smog check. This is what I did and I'm not telling you to do this. What you do with your car is up to you and only you. I'm just saying it worked for me.
If you really want to have a 2 1/2" or 3" exhaust system under your Pinto, first look at your new 2 1/2" or 3" muffler. If its a glass pack, look at the core diameter for a shock. The core will only have a 2" diameter regardless of the diameter at the inlet/outlet of the muffler. Hard to tell on a turbo muffler but I have never seen a glass pack with the core bigger than 2". If you know of one please tell me and the club members. This is the reason why all the mini stock racers use a racing muffler instead of a glass pack. A big exhaust on the street will cost you power unless you drive around at max rpm all the time. Reason is the exhaust gas will travel slower than it would with a 2" pipe and the speed of the exhaust is what aids the scavenge of the exhaust and in turn the horse power. Bigger is not always better. On the street go 2" and enjoy your ride.
Want your stock front seats to be a little more comfortable. Easy way is to remove two or all four plastic bumpers that you can get to when you fold the seat forward. This really helps if your tall too. Take all of them out and you'll look cool in your low rider.
If your like me, after you stake an electrical connector, you will solder the joint too. Right? Well it will take 3 hands to do the job. One to hold the solder iron. one to hold the solder, and one to hold the connector still so you can solder the joint. Where will you get a third hand? Just get your self a small soldering / wood burning iron at a craft store. There used to burn designed into wood. The tip is about 1/8" (.125) in dia, and tapers up to aprox 1/4" (.250). Simply heat the iron up, then slip the small end into the spade / connector and solder away, as now the iron takes the place of two hands. The craft solder iron gets plenty hot to solder too. I use solder that's made for onboard ships and salt water. Solder leaves the connector looking like a pro did it. Have no idea where I got the solder as the roll is about 20 years old. No acid core solder PLEASE. Use only solid core solder.
Want to be the smartest kid with a Pinto? Well this web site can help.  http://www.yarchive.net/home.html   Here's enough info to last a lifetime. Use it wisely.
Ever had a problem with lite sockets sticking when you tried to remove the bulbs? Easy fix is to use Vasoline (spelling?) on the part of the bulb that plugs into the sockets. The vasoline will be there 10 years from now because it doesn't bleed off like oils or grease. It does conduct electric too. This will work on any kind of plug or twist electric connection from head lights to tail lights. Mopars have this trick done to everything that leaves the factory.
Any time you use an electric fuel pump you should get a shut off switch in case you are in a fender bender. Get them out of 90's Fords in the trunk. Most of the time their real easy to find as they have to be turned back on if your in one of those benders. Their on the side of the trunk most times. Well worth the few bucks they bring at the Vega yards /"Uh sorry, the junk yards."
If you have an autocross / road racer / hill climb Pinto with an electric fuel pump and the stock pump too, and worry about too much fuel pressure, you should too. 4 lbs max for a Weber DCOE or a 5200 32/36 Weber-Holley. Only one you need more pressure for is a Holley 2 or 4 barrel carb. Then you need 6 lbs MAX. When you buy an electric pump get the one that's low pressure. 4 psi max for the Webers. If your worried about too much pressure with both pumps on at the same time, just get your self a vacuum switch that turns on the pump at or near zero vacuum. That really the only time you need it. Rest of the time the stock pump is plenty. Get the switch off of E-gay or a large electrical parts house.
Say your going to install a new header on your Pinto. Mfg told you its good for a least 100 more HP. So when you pull off that old rust covered stock manifold you see 3 holes at each exhaust port in the head, but the header will only cover up 2 of them. Easy fix. Just plug the extra holes up. There are several ways. One is to tap the holes, then install set screws. Another is to drive a metal dowel into the hole till it stops. Hole is made with a curve at the end so you can't go too far. Another way is with a small plug like the engine has to seal off the oil and or water from leaking out of the motor. Parts houses have them in all various sizes. Just hammer them in and your set. Which header is best for a 2300 Pinto? All depend's on what you want from your car. Ranger tubing header for cheap and easy to hook up. Ranger/mustang cast iron header for LONG life but heavy. Hooker comp header for a hot rod(hard to find). Which is the best? I think the Ranger/Mustang cast iron is the best if you don't worry about the weight. Sure is pretty too. And it will out live both you and your Pinto.
Need to rekey your door locks. Here's how with pictures.    http://www.mustangiitech.net/index.php?option=com_content&view=article&id=166:rekeying-ford-locks&catid=57:interior&itemid=127   Do this at your own risk. Care full as parts are small and easy to break or loose.
Tired of looking at that old rust covered master cylinder? Well then paint it! I use VHT satin black, but you can use any color VHT has as long as its caliper paint. You must get the master cylinder as clean as NEW. Repeat clean as NEW. Start with a new one if possible or sand blast it. First paint it with several coats per VHT instructions, then let it air dry for 24 hours. REMOVE all rubber parts. Then bake it for 1 hour at 250 deg. That's it and the caliper paint is fluid proof if you don't let it sit on the cylinder for a long time. Remember CLEAN AS NEW FIRST!!!! After you get it as clean as possible, put the cover/lid on it, plug the holes, place in wife's dish washer, and take her out on the town. Remember that this worked for me. Try it on your cylinder at your own risk.
That looks like it would be a blast.
Here's one for all you west coast Pintos. There is a hill climb group in the North West that puts on hill climbs. Our own Pintosopher and EP73 Pinto have raced with them in the past. Looks like a lot of fun with a reasonable cost and car prep.  http://www.nhahillclimb.org  Pintoautocrosser! Have you tried this. Its all around you in the great NW. Try it. You'll like it.
A Ronco smoke eater would give you that much back in the 60's. If you do remember Ronco your older than dirt. I know I am.
Quote from: dick1172762 on January 20, 2017, 10:52:59 AM
Did you gain 50 HP?
50HP! are you kidding? was at least 100HP for that little mod ;)
One picture is worth a thousand words or so I'm told. Thanks cookieboy. Did you gain 50 HP? Hope so.
Quote from: dick1172762 on January 18, 2017, 11:36:37 AM
If you have de-smoged your Pinto and would like a better looking air cleaner try this mod. Remove all the material on the air cleaner that is outside the diameter of the filter itself. Easy to do with tin snips. On the aluminum air cleaners there is a line marked/stamped in the aluminum to show you where to cut. When your finished you will a much better looking and filtering air cleaner. It'll look like a hot rod and clean up the under hood clutter.
I've done it and looks decent
When your wondering about fit and clearance of a new (to you) set of wheels, wonder no more. YOU MUST have 3 3/4" (3.750) or LESS of back space to clear the control arms / springs. A 13" x 7" wheel with zero offset will fit perfect with a 1/8" (.125) spacer. A 13" to 16" wheel with this back space will clear everything on MY Pinto. On your Pinto? Do your own measurement. NO FWD wheels with 2" (2.000) spacers please. We can not afford to lose members. When using 1" to 2" spacers most do not under stand the extra load being placed on the outer wheel bearing. This post is only shown here to tell members what I (dick1172762) used on MY Pinto. I am NOT telling you to use my measurement to buy wheels. Let the buyer beware.
Beware of the 2" drop spindles for Pintos and Mustang II. While they do lower your car while keeping the ride the same, the lower ball joint will almost touch the ground with 13" (stock dia) wheels. Better way to lower your Pinto is by cutting the coil springs 1/3 to 1/2 coils off the bottom of the spring. Then you can still use 13" wheels and ride ok. Newer springs will require more removed but don't get carried away and cut too much. I've used a cut off wheel and a cutting torch. Both work ok with the torch easyer and faster. How ever you do it make sure you get it re-aligned. Your on your own at the rear as Racer Walsh no longer sells the 1" lowering blocks. Not to hard to make and Speedway sell some too.
If your like me and the "pintosopher" and have Weber DCOE carbs on your Pinto, you'll really like this post.   http://www.classicrallyclub.com.au/docs/Tips_tuning_Weber_carburettors_DVAndrews.pdf
Need brackets for building your new hot rod Pinto? Coil overs? 4 links? Motor mounts? This guy has some of the best.   http://www.welderseries.com   Talk to Paul Horton.
Check out what Flowmaster has to say about exhaust tubing size   http://www.roadkillcustoms.com/hot-rods-rat-rods/recommended-exhaust-tubing-sizes.asp#axzz4vgpnoiwy    Bigger is not necessarily better.
If your like me, you would like an easy way to change out your transmission without busting a gut in the process. Get yourself a couple 4" long metric bolts the right size for the bell housing bolts. Cut the head off the bolts/grind the end of the bolt round/then saw a screw driver slot into the round end/screw the bolts into the upper most bell housing bolt holes in the block/now remove or replace the tranie by sliding the bell housing over the two bolts/replace all of the bell housing bolts/remove the two 4" bolts and your done.
Want a better running Ford with an 8 plug head? Just switch the plug wires on the intake side of the head. Switch 1 and 4 then 2 and 3. Switch them at the spark plugs or at the coils. Makes no difference and now you'll have all 8 plugs fireing at the same time. May take a day or two for the computer to catch up and smooth out.
Need a filter for your hot rod Pinto? Then go to  http://www.wixfilters.com/Speciality/racing.aspx  The racing filters are on E-gay every day.
Want a faster steering for your autocross Pinto? Two ways to go here. Get a steering quicker in 11/2 or 2 times less turns for about $150 or less. Either will require power steering unless you pump iron ever day. The other is to use a power steering rack with out the power. Easy to do as the power steering rack works fine with out power. Just use a small length of hose at the rack to hook the two fittings together. Make sure you put some atf in the rack before you hook them together with the hose. I've done this both ways and it help on a tight course. Try it/you'll like it. The best way is with the steering quicker but power steering is a must. The power steering pump required 50 weight oil to get a good feel of the steering wheel. Does take some time to get used to it.
Need a cheap steering rack for your Pinto. Junk yards are out because there are VERY few Pintos out there. But all is not lost. Get one out of a fox body Mustang and use off set bushing. The bushings are only $18 on E-gay today.(off set bushing for a steering rack). I have not done this mod but I have seen pictures of the switch. Cutting of your Pinto is not necessary and you will end up with a better rack due to the tech being 10 or so years newer.
robertwwithee
Cam belt in 20 min on a 2.0.  I belive it as I did one on the side of the road not much longer.  Antiseize on crank pulley does wonders.
Want more power in your street driven Pinto? Try advancing the cam shaft 4 to 6 deg. This can be done two ways. Speedway sells an upper pulley that bolts onto the cam. This pulley has 6(I think) keyway slots to advance or retard the cam. Its well marked so you will not have a problem installing it. The other way is with an adjustable pulley from Racer Walsh/Esslinger. Does the same thing as the Speedway pulley, just takes more time and $$. Make sure you place the bolt that holds the pulley on this way and no other way. You must wrap it with teflond (spelling?)tape this way. Start 3 threads back from the end of the bolt and wrap it with 3 layers of the tape. You must do it this way to prevent the engine oil from leaking out around the bolt. Now go enjoy your power. Don't worry about the valves hitting the pistons as a 2300 is a non interference engine which means their not going to hit.
