Date: 08/08/2018 12:26 pm
SVO SWAP
Date: 03/15/2018 03:12 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Date: 08/22/2018 09:23 am
Date: 03/06/2017 01:24 am
SVO SWAP
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 461
  • Guests: 475
  • Total: 475
No Taillights
Started by blupinto, December 23, 2016, 11:48:00 PM
Quote from: blupinto on December 24, 2016, 03:35:22 PM
I hope I wasn't out of line spilling the Pinto beans! I thought you shared that already. I guess I've really been gone too long from here! lol
Not a problem; I'm rather like you in that I somehow or another felt I was going to jinx everything by talking about it too soon.  After 25 years of searching, the last thing I wanted to do was jinx it!  I was just going to wait until it's in my possession and then wow them with pictures, so if you'd like to post any pictures of it here, you have my blessing.  Merry Christmas!
Dwayne :)
Quote from: Cookieboystoys on December 24, 2016, 06:26:38 PM
had this same problem with one of mine after it got painted. they would work, then not work, then work again, etc. Had a lot of little issues like this after body and paint. It was all grounding issues where fresh paint and grounds went. After much goofing around I finally removed the tail lights. Sanded the area the light plugs go into on the tail light. Used a wire brush on the metal tabs around the bulb mount that hold the light into the tail light. Then because the ground comes from mounting the tail light to body from the bolts that hold it into place I cleaned up the threaded shaft with wire brush. Same for the nuts and some sand paper to the inside around the hole the shafts for the tail light go into so the nuts when tightened would have a clean metal to metal contact for ground. You could just try removing the rear plastic inner shield, reach in and try wiggling the light socket where it goes into the tail light and see if that brings them back, re-tighten nuts and basically wiggle stuff. I did a lot of that hoping it would fix and quit going out. Wasn't until I did the complete tear down and clean all contacts the problem went away for good.
That makes perfect sense to me because that's where the most extensive bodywork was done on the car!  New metal was fabricated back there because when they started sanding, unseen rust caused it to simply fall apart!  Thanks Brian!
Dwayne :)
Thank you, Brian, for that information.  I will start cleaning those things you mentioned in the next few days. I appreciate the insight.
robertbrann18
I have the exact same problem as well. I have a 1974 Trunk Model and my tail lights don't work at all.
1971 Blue Ford Pinto Trunk Model
I don't think there's a fuseable link in the tail light wires. To use the test light just clip the clip on to bare metal and use the point to probe into the wires while the light switch is pulled out. Try the tester on the car battery first to make sure its working and the little lite comes on. Easy as pie R square.
Dick, I do have one of those, but I haven't used it in so long, I've forgotten how to use it! lol
Does this set of wires have a fuseable link on it? (I think I'm saying that right) They aren't unplugged at the lights. They worked when I had the car warming up that morning.
Short of being unplugged at the lights this is a treasure hunt for sure. The tail light wires are easy to trace from the dash rearward. They run under the door sill scuff plate that ties the carpet down under the drivers door. I'm sure you've checked the fuse's by now. One of those trouble lights that is pointed on one end and a lead with a clip on the other will allow you to check voltage along the way rearward. Hope this helps Becky.
Hi Becky!
Well you've let the cat... er, pony... out of the bag!  I really had not told anyone about my "new" Pinto yet, but that's okay; I'm glad you did.  If there's an answer to be found, I believe it will be found here.  Although member participation is down, there is still a wealth of knowledge on this site.
For anyone else who is reading this and is interested, the Pinto we're referring is one that's been a long time coming.  I began my search more than 25 years ago for an orange 1974 Pinto Runabout with black interior, just like the first car I ever owned when I was sixteen years old.  I never dreamed such a once-common car could be so elusive.  In fact, when I stumbled onto this site nearly ten years ago, it was for the express purpose of finding the car I wanted.  I found it quickly; Joe Escobar has it and he isn't about to let go of it!  lol  Other examples were few and far between and I really wanted a decent driver quality car, not a trailer queen or a basket case.  Because Pintos are far more plentiful on the west coast than in the east, Becky took up the search as well and alerted me to several cars she'd unearthed over the past five or six years, but none really quite suited until Spring of this year.  The orange 1974 Pinto Runabout she found did, indeed, have black interior and a newly rebuilt engine.  It's an automatic instead of a manual, but otherwise was the closest thing I've seen to what I was looking for in decades.  She made a trip on my behalf to see and drive the car and, through the modern magic of cell phone technology, we stayed in contact throughout the meeting with the seller, with her sending me photos of problem spots, as well as the good things. We dickered the price down a bit and pulled the trigger on the deal that day!  Although the engine was good, the car had been off the road for quite a while so there were other considerations and Becky has been my liason with mechanics, a body shop, upholstery shop, etc. to get this car into top notch condition.  We're not finished yet and we've hit a stumbling block or two along the way (ie: no taillights) but it's coming together nicely.  By the time I get to see it in person, I will have owned it for about eighteen months, but that's okay.  After 25 years, what's another year-and-a-half?  Maybe I can persuade Becky to post a few pictures of it... it truly is a beauty!
Dwayne :)
Hi All!
              At my home I have Dwayne's "New" Pinto. It has been to the paint shop and looks good enough to eat! When she went there, her taillights worked. When she came back her taillights worked. The morning I was to take her to work (with Dwayne's permission) her lights worked. I know because I go to work when it's still dark, and I did sort of a pre-op, focusing on side markers, taillights, headlights, and turn signal lights. About a mile from my house someone drove beside me on the small "expressway" and informed me that I had no taillights. I pulled over, and sure enough he was right. I turned around and went home, parking her and jumping into my Rodeo.  Since then I have looked up the fuse chart (nothing there for taillights, brake lights, etc.), replaced the brake light switch, checked to see if there were cracks, breaks, wear on wire insulation, changed bulbs... still I have no taillights. Is there something I'm missing here? I've consulted the 1974 Ford Shop Manual, but wasn't able to find anything.  I appreciate any insight or help with this. She needs to be driven, but til this is fixed, it's illegal to drive her.  Thank you.
