Date: 12/24/2016 04:13 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 08/16/2018 08:54 am
Date: 09/15/2019 12:28 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
  • Online today: 1,438
  • Guests: 135
  • Total: 135
brake light switch
Started by ponyboy, December 06, 2016, 01:51:54 PM
Clean your grounds and area around where the bulb sets into the metal plug .Some of the fingers might not contact the light housing IE the ground.
robertbrann18
Haha, I had the same problem. Was a complete pain in the butt to try and replace my brake light switch, then it turns out that wasn't the problem. Still don't have working brake lights.
1971 Blue Ford Pinto Trunk Model
LOL Been there, done that. The car in question is a '74 Runabout, so I'm not sure if it's the same setup.  I'm not so tall, but I'm no Skinny Minnie. It was quite uncomfortable, but I was able to replace it. The irritating part is that the switch wasn't the issue!
robertwwithee
Mechanically skilled to do it.
robertwwithee
Hire a neighbor boy that is mech
FORD PINTO 101  Jack up car! Remove 4 nuts from seat hold down bolts! Let jack down! Open door and remove seat! Lay down on your back in the car and remove and replace switch! Do all the above in reverse to put car back on the road. Even a VEGA owner could do it with some FORD tools. Send me all the $$ you find under the seat.
ponyboy
I need to get to the brake light switch on my '73 4 speed wagon. I got down there with a flashlight, but couldn't even see it. I'm 6' 240, and simply don't fit in there. I considered removing the drivers seat and steering wheel to give me more room. I also considered dropping the steering column. Anyone have any ideas about what is the best way for someone my size to get under there and get to that switch? Would appreciate any help, as the car is not safe to drive without brake lights. Thanks
