Date: 10/24/2018 07:35 am
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
Date: 04/20/2017 08:56 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 05/22/2018 01:54 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
  • Online today: 125
  • Guests: 112
  • Total: 112
suspension question
Started by pmfman, July 17, 2016, 11:08:51 PM
Mustang II front and rear sway bars will fit on any Pinto with very little change. Where the front bar fits onto to the frame will need to be moved forward about an inch. That's all and some Mustang II's with a V-8 had a one inch front bar.
Quote from: pmfman on July 18, 2016, 11:25:44 PM
would a 78 classify as a later pinto? or do you mean the 79/80?
I know the 77-80 wagons have the larger bars but I do not know about the 74-76.  I know the 72-73 wagons had a smaller diameter front bar if it was equipped.  I believe the front sway bars were an option back then.  Mustang II bars have a slightly different shape.  Not sure if they would work on a Pinto.
Francis Stanisci
Aren't the Mustang II parts interchangeable?
pmfman
KDC
The sway bars on the later wagons are larger than the sedans/hatchbacks.  They are a bolt in, you just need the frame bushings.
pmfman
I have a 79 pinto with a stock(ish) motor, however i am trying to reduce body roll, does anyone know of a beefier sway bar from another car that would be an easy replacement? are the sway bars in the wagons any stiffer?
KDC
