parts needed
Date: 02/20/2017 07:58 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 02/18/2017 04:41 pm
Date: 04/20/2017 08:56 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 03/23/2018 09:23 pm
Date: 12/10/2017 01:14 pm
Date: 08/05/2018 01:58 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
  • Online today: 1,166
  • Guests: 491
  • Total: 491
Power to manual rack swap
Started by Darren Laih, June 25, 2016, 02:58:41 PM
72pair
I got lucky and found a pinto in my local pull a part. I was actually searching other fords for something with the same shaft/spline when I stumbled on the pinto.
Rob3865
Quote from: 72pair on June 25, 2016, 04:59:30 PM
On my 80 Bobcat, I had to change tie rod ends and the rag joint coupling for the manual specific pieces.
I am doing the same thing. Would you mind sharing WHERE you found the manual rag joint? Thanks.
Darren Laih
72pair
Darren Laih
Quick question is the swap from power just a rack change and remove power steering pump or is it more involved?
