1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Date: 03/30/2021 12:29 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Date: 01/28/2021 03:49 pm
Date: 06/07/2021 08:14 pm
Date: 07/08/2017 08:53 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
windshield
Date: 04/14/2018 08:53 pm
  • Total Topics: 16,268
  • Online today: 148
  • Guests: 77
  • Total: 77
Purpose of pipe coming off the exhaust manifold?
Started by Walston, May 05, 2016, 09:13:26 PM
Are you in California ? What year will the car be registered as ? Pre 1974 get rid of it! After 1975 it's part of the Thermactor system for emissions. This system was used on most Ford cars until the EEC-IV came out. So if you have to have it you should be able to get parts. That dryer as you called is an air bypass valve or the air bypass valve. As per the Ford Car Shop Manual 1975-1976.
I looked at the 1977 2.3L parts car I have and it doesn't have anything matching that description. It has an air line from the smog pump to the exhaust manifold and an EGR line from the exhaust manifold to the intake manifold.
On your engine it sounds like EGR-related parts to me.
Sounds like you got some smog stuff that was half removed , like the smog pump and hand full of vacuum lines ,
Post some photos of what you have now , a picture is a thousand words 🔩
Walston
So there is a ~3/4" pipe that comes off the exhaust manifold, it goes towards the front, has a coil for cooling, goes through what looks like an air conditioning dryer, then a hose that goes to the air cleaner. I assume this is some kind of emission devise. What does it do and do I need it? I would like to use a smaller air cleaner (Weber) and need to know if I need to keep this thing.
Walston
