1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 02/11/2020 12:09 am
Date: 08/01/2023 06:53 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 06/30/2018 09:48 am
Date: 06/18/2018 03:47 pm
Date: 01/23/2023 02:22 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 09/15/2019 12:28 pm
  • Online today: 1,166
  • Guests: 129
  • Total: 129
Tired springs and air shocks
Started by JoeBob, March 25, 2016, 05:45:07 AM
Just fyi in case you don't know, air shocks on a unibody car are not the best idea. Been reports of lots of problems with the mounting point on the body not holding up. At least in the vintage Mustang world. Maybe the Pinto is reinforced in that area?
Might be ok, but just something to think about.
I can't imagine it costing $1200 installed. Can you check around with other places?
76hotrodpinto
If they are the same as a 75, I have an extra set that sat well and were stiff. I would let you have them, if you want to pay for shipping.
enzo
I had new set of rear springs made at a spring shop for about $400.
Take a look at Speedway Motors under the mini stock heading.  They have springs listed
for less than $175 each with spring rates from 104 lb to about 140 lb.
That seems like a LOT of money for springs even including labor.  I'd think half that amount would be correct.  Is it just the rear, of the fronts too?  I assumed rear only because you address air shocks and they are typically not used up front.  While they may not make an air shock specifically for the Pinto (rear) it doesn't mean that something isn't available that could fit.  Many shock manufactures have the specs of their shocks listed on their websites.  Find those for the Pinto and then check to see if anything is available in that compression/extension range.  It may require the connection end being modified too. Fortunately for the Pinto the Mustang II lower mounts offer another option.
Hopefully those who have had springs replace and give you a more accurate price to compare.
JoeBob
My springs have collapsed. I need to pay to fix this, I am too old to do my own work anymore. New springs etc will cost $1200 plus. Air shocks would seem to be the answer but my mechanic can't find any. Anyone have any Ideas?
77 yellow Bobcat hatchback
Deuteronomy 7:9
