  • Online today: 1,166
  • Users: 1
  • Guests: 133
  • Total: 134
  • rob289c
Trans. fluid leak from downshift lever.
Started by fastfred, February 07, 2016, 12:30:47 PM
great , glad you got it fixed , guess over the years they changed , mine had a O-ring in it , later Blaine
fastfred
Thanks for the reply. I have fixed it.  Behind the lever there is a seal, not an "O" ring as such. Part # 759003 at O'Reillys. No need to remove the pan.
Thanks  Fred
If you are sure it is leaking from the down shift lever it is just a O-ring , remove the nut and lever and use a pick to remove the old O-ring , install new one , if it's the shifter shaft you have to remove the pan , the nut on the inside , and a small pin in the middle of the gasket area , use a small vice grip to remove it , you do not have to remove the valve body to do it , if the parts store does not list it use a 93 ford ranger with the A4LD , it is the same seal ,
fastfred
Transmission fluid is coming from behind the downshift lever on my C3 automatic.  Am I correct in thinking there is a small seal behind there that can be replaced when the lever is taken off?  I thought it was the trans. pan gasket at first which I have replaced but it seems to be the seal. Anyone?
Thanks Fred
