windshield
Date: 04/14/2018 08:53 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 08/09/2018 11:09 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 10/25/2019 03:30 pm
Date: 05/22/2018 01:54 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
  • Online today: 3,091
  • Online ever: 3,214 (Yesterday at 10:48:59 AM)
  • Guests: 2729
  • Total: 2729
need Help
Started by Mario333, January 13, 2016, 07:12:45 PM
My first thoughts would be choke stuck or float not working. Try a quick shot of starting fluid.see if it will run. Now you have vacuum lines back in place may need to adjust carburetor.
Mario333
I have spark and there is fuel being brought to the carb. It almost starts but won't.
Just one filter at carb. Are you getting spark?
Mario333
Thank you for all the advice!! Ill look into the switches. So today was the day to go work on the lights, yesterday I took it for a drive during the day and she got nice and warm but was driving fairly rough. Once I got to my destination which was my buddies house I did some looking and found some vacuum leaks. Once those were fixed the car ran great. Idled properly and ran/braked miles better.  I drove it home before dark and parked her with the intention of going back this morn to do the lights. Car will not start. Turns over and no matter what I do with the gas pedal be it flat to the floor or anywhere in between there is nothing. I suspect no fuel is getting to the motor. Where are the fuel filters on these cars? Is the main along the frame rail? And the secondary under the hood somewhere?
Local parts store should carry the dimmer switch they were used in most cars until the 80`. You used to be able to get the parts to rebuild the signal switch in the help section. Pull the fuses and do continuity test. I had one that looked good but the soder had broke so i had no blower for 3 years. The unplugged wire may just be an unused wire.
If needed, rockauto.com advertises replacement dimmer switch, turn signal switch, head light switch, and wiper motors but not the wiper switch.  If doing a lot of electrical investigation, suggest getting the 1980 Pinto Ford EVTM.  Ebay is a convenient source, search on: 1980 Pinto, evtm, electrical & vacuum trouble-shooting manual.
Mario333
So I bought a 1980. Recently had alot of money put into he motor drive train etc but had not had any work done to the electrical or interior. I have headlights (stuck in high beams as floor switch is seized) and brake lights, but no turn signals, or running lights. The heater fan worked like a champ and the wipers worked as well till yesterday. I'm going to retrace the wires again but they seem to be fine. The fuses all seem fine as well. Any suggestions? I may add there is a grey plug hanging under the dash unplugged as well that I have yet to pinpoint it's location.
