2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 02/18/2017 04:47 pm
Date: 08/22/2018 09:23 am
Date: 07/08/2022 11:51 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 02/14/2018 01:34 am
oldskool787
Date: 02/12/2017 12:42 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
  • Online today: 1,972
  • Guests: 988
  • Total: 988
A arm / suspension
Started by yhalkeeiron, December 02, 2015, 01:36:06 PM
jwpauto
I can tell you for sure the LCA bushings from a 74+ are much wider than the '73-. I think it would be safe to say that the 74+ LCAs are wider at the crossmember than the 73-.
yhalkeeiron
Ok thanks. And yes they are a little different the Pinto a arms are little  shorter than the Mustang2/ Pinto. And also the cross member is different 2. I think it'll will be interesting to know how much it will take to get them to work
Sent from my SM-G900P using Tapatalk
It's a totally different design.
You might be able to adapt the newer ones, but it is not a bolt on of any sort.
There's got to be some previous posts on that subject around here somewhere.
yhalkeeiron
Does anybody know what the difference between the early 1973 and under pinto a arms . Compared to the 74 and up. I do know the spindles different and the rotor and caliper are different. It looks like the bottom a arm is longer on the 74 and up by an inch.
I'm just wondering if anybody installed new tubular a-arms on their 73 and under Pinto? because the only ones I could find say 74 in up
