Date: 07/17/2018 09:49 pm
Bell housing
Date: 08/23/2017 05:41 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 09/05/2018 06:30 pm
Date: 01/23/2017 07:41 am
Date: 03/14/2020 01:52 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 02/21/2017 06:29 am
Date: 04/21/2017 02:03 pm
  • Online today: 183
1977 to 1980 interchageable parts????
Started by D1, September 13, 2015, 09:50:26 AM
The 4 cyl trans will not bolt up to the 2.8 , even if you got the belhouseing , if you want to keep it stick you have to find a mustang two four speed belhouseing and use the T-5 trans , the 2.8 will swap easy , you may have to swap out the front coil springs , all wagon use the same tail lights , wagon doors will fit all wagons , sedan door will fit all sedans ,
D1
Thanks guys.....so the tail lights and rear marker lights WILL change???....Will the engine change with ease or will I need to redo front suspension motor mounts etc...this one is an auto....mine is a stick....if I wanted to stay with the stick......bell housing and flywheel SHOULD be the only change for that, correct?
Thanks
May the Lord bless
Romans 14:11(KJV)
The doors will bolt on but in the back /top the sedan has a curve for the roof line , the wagon is straight , the grill , marker lights and running lights will not fit , unless you use the fenders  and hood , side door windows are straight on the wagon , I am putting a 75 front end with a 76 grill in my 79 Cruze wagon, the windshield from the 77 would fit the 80 but you have to buy the gasket that goes around it to do so , but I would keep the one you have in the 80 , its glued in like the newer car and less chance to leak , wheels and every thing is the same , to 77 has a 8 inch rear because of the V6 , use it , hope this helps , and also do not throw anything away , you or someone in the future may need it , 🍺
You should be able to interchange just about everything including the windshields if you wanted.
D1
Trying to decide if its a good investment to purchase a 77 cruising wagon with a v6.....I have an 80 sedan wagon with 4cyl......how hard is the change for these 2 engines?.....I know the windshield will not change out..... I am more thinking grill, marker/running lights, doors, back glass/window, doors/door handles, wheels...etc. etc.
thanks.
Thanks
May the Lord bless
Romans 14:11(KJV)
