Date: 03/07/2017 07:03 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 08/26/2018 06:35 pm
Date: 09/15/2019 08:30 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 01/19/2020 09:06 am
Pinto Watch
Date: 06/22/2019 07:16 pm
looking for parts
Date: 06/19/2020 02:32 pm
  • Online today: 1,166
  • Guests: 523
  • Total: 523
Clutch help
Started by ToniJ1960, September 11, 2015, 08:13:34 PM
ToniJ1960
 My cars been getting more and more difficult to shift into first when its running and warmed up.
Now I had this car since 1986 so I have had to get the clutch replaced a few times. And a couple years ago I replaced the cable, the two before were so cheap they wore out the rubber part that keeps it from going through the firewall. This one seems better made with a metal part at that end but....
Well when the clutch has gone out before this was the symptom then and new clutch always fixed it.
I wanted to try to be sure before I spend the $ even though this ones been in there for about 8 years.
So I went to adjust the cable thinking I would adjust it opposite the normal way to remove freeplay. The pedal did have a lot.
The adjuster nut was stuck, I got it off the bell housing and got it freed up, and adjusted it. When I was tightening the lock down nut, it wasnt getting real tight. Then I thought oh oh, I remember this. The rod gets pulled through the threads on the plastic adjuster nut, and the rod gets pulled in, adding more freeplay. Thats why the nut was jammed I guess?
Checked the pedal it had more free play than it did after I first adjusted it. I think Im on the right track. I need to put the old Blue one on this new cable.
What do you think? Maybe time for a new clutch or has this happened to you? Cant it drive it just yet.
