Date: 04/28/2018 04:12 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 11/04/2018 02:34 am
6.6.75 carrier
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
  • Total Topics: 16,268
  • Online today: 339
  • Guests: 132
  • Total: 132
72 DutchWagon rolling resto
Started by 72DutchWagon, September 05, 2015, 07:48:18 AM
robertwwithee
Yea, by plane.
72DutchWagon
He Robert, if you're coming by boat, could you take an 8 inch with a fresh pumpkin, fiberglass body parts, a full racing cage, eh, but I guess not, Aeroplane I presume?
There are still (always are) some bits that I need from the States, let me think about it, I'll send you a PM later to discuss practicality.
76hotrodpinto
It's small, weird little planet we're on.
robertwwithee
Quote from: 72DutchWagon on February 01, 2016, 02:10:57 PM
Thanks for the remark!
ASML in Eindhoven? A microchip man who digs stone age technology?
Always welcome to come take a look at my donkey (and go for a spin).
And I just might take you up on that offer some time...
May 22 till June 3, I'll be there in veldhoven, staying in Eindhoven.  Do u need something for donkey that I can get?
Your probably right on the ign switch , you might have to wait untel you have that problem again, then you drop the steering colom and check the switch then ,power should flow through all the large yellow wires , and the car looks great , 👍👍👍
76hotrodpinto
It's cool to see the pinto has it's place there too.
There's a tubbed out capri carcass for sale here, that's been haunting my dreams lately. It's almost the same shade of blue as the one you posted.
I had one of them Mercs, nice riding car..
I think you might be on the right track with your thoughts about the ignition switch... I had a 1983 F-150 that did that.  All I ever had to do was cut it off and restart it and it would be fine.  Probably worth looking into.  As for the photos, I LOVE that Mercury!!!
Dwayne :)
72DutchWagon
Donkey has past the biannual road test!
A few niggles had to be ironed out by the (luckily!) classic loving crew at the shop that did the test, including welding a small patch.
After that, the only  problem I ran into once, was that I lost all electric power to the accessories, engine was running fine, but I had no power to the dash (fuel gauge) wipers, turn signals etc.
I treated the fuse box to a dose of contact spray, and the problem went away, but I also have a suspicion that it might have to do something with the ignition switch not returning to the right spot after starting?
If anyone knows the exact cause please tell me because it's not something I'd like to see coming back.
Today I took the wagon to the Antwerp Classic Salon, Antwerp is just half an hour away and we enjoyed the trip.
On the parking I left  Donkey in good company and had a nice time at the expo. I bought some brake line wrenches and I spoke to someone who might have a Mustang II 8 inch rear for me, fingers crossed.
I added some more Ford product images for your pleasure.
72DutchWagon
robertwwithee
It's nice to read your posts 72 dutchwagon.  I'll keep you in mind on my next trip to Netherlands.  I work for ASML.  I could bring a part or two over.
72DutchWagon
A few months ago I changed the turn signal cam because it was broken.  Now I found out that my left brake light wasn't working, and there was nothing wrong with the bulb.
A quick search on the net revealed that with Mustang's (same steering column)  the problem is normally in the turn signal switch, and you have to get a new one.
Now Rockauto doesn't show these for 72 Pinto's. I just took the risk of ordering one for a 72  Mustang w/o tilt, OE PRO SM44F, and it's all right. A few wire colors are different, but it's just plug and play.
72DutchWagon
Got the car back in the garage to do some work, have to pass Dutch APK test in March to be  allowed on the road for another two years.
When I removed the left side panel to run through the fuel pump wires (they had been lying on the floor since summer) I discovered  a lot of bird feed left over's, some chewed on hazelnuts, and a door post cavity stuffed up with what looked like plucked carpet (so that's where the carpet went?). Did once strange lodgers live in these premises!?
Didn't find any animal droppings though. I  cleaned the lot out, and this corner will probably at some time need some welding and anti-rust treatment.
The brakes needed attention too, left back drum kept locking up, on inspection I found out that I had different setups left and right, on the right side two equal length brake pads, and all kinds of incorrect fitting.
Up till now I've replaced the rear shocks,  rear drum brake hardware and emergency brake cable.
I included a picture of the plastic emergency brake handle cover, this kind of stuff is so easy to break before you find out how it clicks open.
I see what you are against DutchWagon ,  and how do you get it certified ? ,  maybe if you over built it they can put a lower rating on it , (down to what you need) I have towed trailers with my pintos since day one back in 71,  but the toe hitch,s are getting raire,  still looking for the old early hitch but as you said it can not block the plate , so what you might want is like the one on my car , its a old class two , 300lbs tougne wt, 3500lbs trailer , receiver type , yes over kill for yours but fill the bill for what you want to do , and being a old american car they do not know what came with it , its older than the guys that want it inspect it , have a good welder make it up , then dirty it up like it looks old as the car and say it came with the car , and show photos of mine from the USA , just a idea good luck
72DutchWagon
Nice to see that we've got the official Pinto trailer hitch story covered now, and well documented!
Building your own is an option but not legal around here, it needs to be certified.
Another problem is that a hitch that is partially blocking view of the licence plate can also result in a fine in The Netherlands, you then need a removable hitch.
Looking at the moderate towing weight capability, it may just be too much trouble to spend time on.
Is it an option to build your own hitch? I've built 2 for custom applications over the years & plan to build 2 more for 2 of the Pintos so I can run a bike carrier on them.
Blaine's hitch looks like the one I had on my 71 Runabout, see photos.  Mine is bent up a bit from my attempts of body stretching after a rear end collision.  Mine was made by Draw-Tite Co. out of Belleville, Michigan with part number of: PIN 1 IK.  Draw-Tite's web site no longer shows hitches for Pinto's.  Your Ford instruction sheet appears to be for similar hitch, look at how it bolts to the bumper for a difference.
If you end up using a similar hitch, I recommend reinforcing the mounting points.  I added full width angle iron to the rear floor and inside the rear bumper to spread the load .
72DutchWagon
I see, you've got the original part for which I did find the fitting instructions (also have these in bigger readable format). On this it didn't state that it would work for wagon's too.
In Europe we don't see flat metal trailer hitches at all, the ones we do have need some sort of certification to be legal.
I'll think about the how's  and if's for a while, no hurry, thanks again for your help.
Got you a photo , the sedans and wagons bolted the same way , a flat bar bolted to back of the spare tire tube with two 3/8 bolts and large washers on the inside , the middle of the flat bar had one 1/2 stove bolt from the inside going to the rear that went though the 90 degree bent tongue that went over the top of the Hourse shoe brackets you see bolted to the bumper , I think it was only good to a tad over a 1000 lbs trailer weight , and 250 lbs tongue weight , this is from memory will look and see if I can find it to see what is stamped on it ,  Later Blaine
Nope , but let me look and see if I still have one , it was very simple the way it bolted to the car , it fit the sedans also, it would be easy for you to make if I can get a few photos for you , later Blaine
72DutchWagon
I just ran into an add for a trailer hitch on a Dutch site, advertised as a Mustang II part.
Does anyone have an idea if this might fit my 72 Wagon?
looks like you got it running good DutchWagon , as for the vibration it could be the drive shaft , if you cut it and did not have it bailanced after , hard to do no mater how careful you try , had mine done when i cut mine , do not worry about the play in the diff, as long as it is quite its ok, might just want to change the oil in it ,
76hotrodpinto
Thanks for the pics! It's cool to see that many "foreign" fords. I had a german capri when I was younger. I would love to have it back now. It was just a cheap runner for me, back then, but now I see how cool it really was. Your donkey looks about as out of place as mine does at shows here.
(pics from before motor swap)
72DutchWagon
Yesterday I took donkey to the National Ford parts day, a 200 mile round trip to Barneveld.
It's not a huge event, and on the parts side, there's not much for donkey to be found, it's mostly for European Ford products.
The images show Taunus, Consul/Granada and Capri's, not a Stang in sight.
Most people had never seen a Pinto, some didn't know that a wagon was made.
The trip was a good try-out though for the car, average highway speed was between 75 and 80 miles on the gps.  Mpg was around 23. No major problems, no leaking or overheating.
There is lots of vibration going through the car, think I'll have to take it to a drive shaft specialist. I also have excessive play in the diff,  but no whine, could that add to the vibes? Any other known vibration causes that I should check out?
72DutchWagon
Thanks for the extra info Blaine, I did loosen the three phillips screws and pulled some on the complete unit but didn't know were it was going so stopped. Next time I'll take it all out.
Would have been so much nicer on the table with an autumn specialty bock beer (yes, cold please) next to it, but on the other hand, then I would probably have got the wires wrong and indicate left when going right.
Yep and we dump ice in our Tea also ,  but as for my wife's cooking I sometimes have to quickly eat it before the taste catches up, 😵😵
76hotrodpinto
Or a warm beer. You never know, over there in dutch land.
so i guess it was a alternator problem you had and got it fixed , great , on your turn signal switch , do you know it does come out the top, in case you do not you remove the lower plastic cover and you will see a curved plug in connector , you un plug it and will all slide out so you can go and work on the table next to a cold beer ,  :o
72DutchWagon
Three jobs done last weekend; conversion to one wire Powermaster B 57141 alternator, replace turn signal cam, and put new pedal rubber on clutch pedal.
I wanted to (over)kill the insufficient battery charging problem once and for all so opted for a 140 amp Powermaster one wire conversion. I read tons of posts on forum's about how this is supposed to work, and all I read was that "it only takes one wire".
I know there's more people that would like to hear the complete story so here's how we (me and my stepbrother) did this.
This Powermaster alternator's case has the same mounting measurements as the 40(!) amp original, so no changes to the brackets. I also ordered a 112 double v-belt pulley, so now I can run double belts on the original double belt Scorpio pulley's. First we ran a earth wire from the top alternator bolt to the chassis. We discarded the original black charge wire that disappears into the loom (on its way to the dash) and taped it off. The other two wires (that go to the voltage regulator) were also secured out of the way. The connector on the voltage regulator was removed and taped off. The voltage regulator was taken out.
From the alternator we ran a new 4 AWG wire through a 150 amp mega fuse directly to the battery plus post. The starter wire was connected to the charging post on the alternator (keep in mind that I already did a mini starter conversion and bypassed the standard solenoid). From the battery plus post we ran somewhat thinner wire to the plus side of the solenoid.
That's it, we can later add a voltmeter, run from  the #1 terminal on the alternator (that would be the third wire coming of a one wire alternator...).
Replacing the turn signal cam (Dorman 49301) meant removing the steering wheel with a puller, cutting the original wires and having to shorten them even more because they were worn through in several places. Then it's a fiddly job to get the wire connections done and get everything tucked away in the least stressful position.
After that, fitting a new Dorman 20731 clutch pedal pad was a 5 second job.
You might have to do a volt drop test on the car , what you have to do it start it up and run for a few minutes and then turn the lights on , all of them ,put the fan motor on low or med, take a volt meter and check what voltage between the alternater and battery, if you have more than a volt you have bad wires , over the years they get hard and the resistance goes up, also check engine to the negative post on the battery , that will give you fits, I put two ground straps on mine , and last is see what is stamped on the alternator , I do remember some were stamped 42 amps or less 😳, I have one off of my parts car and it was a 60 AMP, (see photo) , I have a larger one on my V6 pinto , it's a 100AMP , and last on your cam is if you have to remove it you have to remove the head 😩, yep the cam is removed from the back , so if you have a non A/C car you can remove the radio and use a hole saw on the fire wall to remove the cam, but remove one the the rocker arms and look at it , if it is smooth across the face just install it back and adjust the valves and keep on going , get a zinc oil additive, most oils do not have them because most engines have roller cams instead of the old slider cams , hope this helps
