74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 10/31/2018 12:04 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 02/03/2018 11:28 am
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 07/11/2023 11:39 pm
Date: 01/28/2019 05:15 pm
  • Online today: 2,399
  • Guests: 1488
  • Total: 1488
72 DutchWagon rolling resto
Started by 72DutchWagon, September 05, 2015, 07:48:18 AM
72DutchWagon
My European Pinto 2.0 EFI is run by  a Ford EECIV ecu, similar to the ones in loads of eighties and nineties American Ford's, not with the same software and components of course.
As I am contemplating to get a newer aftermarket ecu somewhere in the future, and I had been thinking about a step by step reversible transition, I went searching for an extra EECIV connector, so I wouldn't have to hack up my original Scorpio injection harness.
The connectors are available new on ebay, but most without terminals, or very pricey.
I found a cheap complete Focus ecu at the scrappy, but then came the real issue, how to get 60 pins desoldered from the PCB. I read all sorts of info on forums but nothing worked, gas torch or heat gun are only good for destroying the lot. Desoldering with a soldering station didn't work, the heat seemed to flow away in the circuit board, the solder wouldn't melt. Buying a real desoldering station for this one job was a step too far for me.
I ended up grinding away the PCB around every single one of the sixty pins with a Dremel, after that the heat of the soldering iron was enough to loosen the small "diamonds" left around the pins.
Now with an extra connector, I could even make a breakout box like this guy did: http://www.merkurclub.com/kizerweb/scorpio/misc/tools/breakout.htm
That way I could hook up anything to the existing harness for testing purposes.
72DutchWagon
For the last half year I've been using Donkey as a car without spending any extra money on it.
Come fall, I did think that it was time for a service, new oil,  filter, brake fluid etc.
All went well except for a stuck brake bleeder and a loose grease nipple on the left front side.
So the caliper had to come off, used lots of WD40, put a nail in the stuck bleeder to prevent it from collapsing and with the help of a pipe wrench managed to get it out in one piece.  New brake bleeder was Dorman 13901.
That was one problem fixed, then the other one; I enlarged the grease nipple hole, cut new thread and fitted a larger nipple.
I had some time to spare so decided to pull out the chairs and rubber mats and check out the floors and maybe test fit Blaine's carpet. As this required making holes in the carpet for seat belts, handbrake and shifter, and not having a Torx T50 bit lying around for removing the seat belts I decided that this would have to wait. I also discovered two places in the floor pan that will require a small patch welded in. Moisture and time will eventually take their toll on everything, and the fact that there is a lot of kit used around the front windscreen, and the original carpet being replaced somewhere in the past  by a few pieces of rubber mat,  indicates previous moisture problems.
This car does have an old rust prevention undercoating, which has helped it staying in good condition for a long time,  but it's past its prime now and will need removing before fixing the floor.
Another nice job for maybe next spring, the seats aren't falling through the floors yet!
72DutchWagon
I'm back with a real life" way past sell by date" story, a reminder that after years and years of use, some parts will give up.
In this case it was one of the tailgate springs that broke with a loud bang. First I didn't know what had happened, until I lifted  the tailgate again, doesn't stay up any more (now where did I hear...).
Have to figure out a way to bend something like that and put it back in.
Must say that I always was most impressed by the installed system, as it remained functioning correctly for much longer than any lift support strut that I know of.
72DutchWagon
Donkey passed its  road test in February without any real problems, new windshield wiper blades and fixed high beam warning light and good to go for another two years.
March the third was time for Antwerp Classic Salon again, weather had been quite bad the night before, so almost no classics in the snow  on the parking. Donkey couldn't care less, he just wants to go out and about.
Inside wasn't  much better, not one  Pinto engined classic in sight, so all I have for you are an ridi- ahum –meticulously restored Mustang (with too many factory quality control markings for my liking) and a couple of vintage Shelby's.
I won't bore the hell out of you with all the Porsche's, Lagonda's, Benz's etc. that were also there.
I really think everything will work out ok. You seem to have a really good hold on your Pinto. Just keep up the good work next spring.
72DutchWagon
Donkey's engine is all back together again, and with fresh head, cam, cam belt and coolant is running around as happy as ever. I haven't really tried yet, but it seems to have more pulling power from low rev's.
As it is now I hope to get through the winter and pass  road test (every two years) in March. Time to do some work in the house and think about what to tackle next (spring?).
Plugs look good. What I was talking about was the different look of 1 and 4 in relation to 2 and 3 pistons. Most of the time all 4 pistons will look nearly the same if the engine is not totally wore out.
72DutchWagon
Well  Dick, as you might remember, I  acquired this engine and T9 box in December 2014, packaged in a  roadworthy 85 Scorpio with about 120.000 miles on it, which is far too little for a 29 year old car.
Probably it was first owned by a German pensioner, and after that imported to The Netherlands, and it might have been standing for a long time before I bought it.
I ran it for about 500 miles to see how it went, took it over 100 mph in that time, then dismantled the Scorpio, and plonked the lot in Donkey without opening anything up.
It has been serving me faithfully to this day, so "if it ain't broke, don't fix it" seems to be true in this case.
What you see is as new to  you as it was to me the day before when I took the head off.
Different burn pattern; might the flash light of taking the picture make it look that way, I hadn't noticed? Look at the spark plugs in the right order, nothing strange  there I think?
The coolant that I renewed in 2015 is completely rust brown, so will be changed again now, I think that also points to the engine having been standing  unused for long times before 2015.
Today I only had time to change the rubber mounted center piece of my adapted Scorpio trans mount, which is holding up  nicely. The rubber was almost eaten away (after 32 years), see through in some places, so I got a new one from Burton's.
Why are we seeing a different burn pattern on pistons 1 and 4 than 2 and 3? And why is there rust at the top of all cylinders?
72DutchWagon
Well, 85 mph in fifth (after fitting new tie rod end) with 195/65/15 is no problem,  even up a mild gradient, and there is still power left.
Now Donkey is back in the barn for head  and trans mount exchange.
85 head is a little tired, so I had my spare 90 head reconditioned and updated with Kent cams FR34 injection cam, should give more torque from 1000 rpm, not that it was lacking in that department, but a little extra...  You know.
Cylinder walls look fine to me, except for the rusty edge at the top, but I'm not doing anything to the block at this moment.
Head bolts were exchanged for ARP studs, later Pinto 2.0's have one time use only stretch bolts, don't like that  idea.
72DutchWagon
Action shot of Donkey, hauling old iron to the scrappy, $ 0.08 per lbs, 290 lbs, small reward for cleaning out the garage.
Second pic is winter wheels, 15 inch steel  Peugeot wheels, offset about 1 inch, tires 195/65/15, circumference 1994mm/78,5 inches. . These wheels are very easy to find over here.
I think this is about the tallest tire you can fit at the front without rubbing.
Whilst changing the wheels I found one of the reasons for the sloppy steering feel, left tie rod end is loose, better change that out (fast) before tackling the steering shaft.
When this issue is corrected I'll go and find out if 5th speed will still pull a tire this tall.
72DutchWagon
My 90 2.0 head is back from the engine shop (in a week!) and it really looks good.
The engine shop owner even fitted new camshaft bearings, oil seal and better quality valve stem seals without extra charge.  He must have a weak spot for Pinto's, I found out he races them himself in Formula Ford competition.
Having this done by a professional is not cheap, but I don't think you can clean up a head like this at home without the proper experience and equipment.
Hope to be able to exchange this one with Donkey's tired head in the near future.
Something I definitely overpaid on is a scrap yard Mustang II steering column and steering shaft, particularly because I'm probably only going to use it for measurement purposes, I intend to get rid of the 71 72 flexible steering shaft.
I've always had the idea that there is too much flex (not play, flex) in the steering, and now it feels worse with wider wheels and tires, and the somewhat wider track at the rear (spacers).
I'm not going over 85 mph at the moment because it just feels scary, like having a heavy  crosswind  when there is no wind at all. It also feels strange driving slowly on uneven surface.
Not so much trouble in a curve, but very noticeable in a (fast) straight line.
45 years and countless miles of service may of course be a lot to ask from a flex shaft.
72DutchWagon
I'm disassembling my spare 1990 Pinto 2.0 EFI head, factory hardened valve seats, what a luxury...
This one should got to an engine shop for cleaning and tune up, will be fitted with Kent cams FR34 injection cam, and will then replace Donkey's 1985 EFI head.
72DutchWagon
Here are some pics of 15 inch OZ wheels all around on Donkey. I decided against using spacers on the front, just custom made a few hub centric rings with a 3D printer. Tires are 195/50 at the moment, but they are quite old, might go for a little taller in the future. If I go to 195/60, the circumference would be about the same as the 185/70/14 wheels on the Scorpio that donated its drivetrain, we'll see.
72DutchWagon
8 inch is finally under Donkey, and with some Italian 15 inch OZ superturismo wheels added it's back on the road. Adaptation for wheels gave some headache, but now I've got a wide choice in four bolt wheels with an ET of 27 to 28mm originally intended for primarily Peugeot vehicles. That 27 to 28mm ET is around the 1 inch mark, which is the standard ET for a 72 Pinto according to the Ford car shop manual.
It meant custom milling on the inside of standard 25mm spacers  intended for Ford to fit on the 8 inch axles,  and adding a centering ring on the outside to compensate for  the slightly bigger center hole in the wheels intended for Peugeot.
Most important reason for taking this route is the low ET, most modern wheels have much higher ET's  and are not usable in this configuration.
Front wheel spacers  still have to be adapted (more milling) so at the moment the front is still running on stock steel.
So far I'm happy with this conversion, less play in driveline, less noise, feels more stable and better  diff ratio, 3.55 to 3.40.
robertwwithee
Very nice work Geert. I need to do that
72DutchWagon
72DutchWagon
Thanks Reeves, that was not on this little project's list, better find some new ones then!
Cannot answer your question above.... but just an FYI - you cannot (should not) use the old U bolts.
Any spring shop can make you new ones.
72DutchWagon
No worries Blaine, I was aware of that, saying goodbye to the 13 inches anyways.
There is one other thing that I would like some advice on.
In Bob2000's axle conversion story there was a mention of the 71-73 Pinto's having  a round centering point for the rear end on the spring saddle, the 74-80 Pinto's have an oblong hole in the spring perch (see images).
I already knew that the 6 ¾ rear end  under Donkey wasn't the original one, because its tag read WGF-N, which would be a 74-76 rear end (but with 71-73 axles?), and it has the oblong hole, like my 8 inch.
Now, the previous axle swappers didn't see any point in adapting the perch hole to fit exactly to the 72 centering point, and it never was an issue. I guess that sideways the play is only 0.04 inch either way, which isn't worth looking at, and front and backwards, the positioning of the axle is more or less fixed by the U-bolts. Once tightened up I don't believe it's going anywhere.
What do you guys think?
I hate to be the one to tell you this but your going to have a wheel problem , the center 71 to 73 wheels
will not fit the 74 up hubs , they will not slide all the way on ,there is a fix for that
72DutchWagon
spring has past, no news...
Had to start sometime on axle change, Donkey is back in the pits.
Car looks great ,  I hope you keep it out of the mud since you don't have mud flaps anymore .  ;D
72DutchWagon
So sad to have to say farewell...
To a period accessory; the tin mud flaps have reached the end of their working life, all battered and with torn out bolt holes they have to go.
To soften the loss I took Donkey on a 130 mile round trip to the "American Day" in Boxtel.
Here he was in rather exquisite company, but still drew attention for being a true rarity, no Pinto's here, let alone wagon's.
I might have tried to enter the "concours d'elegance" competition, but in hindsight, that would have have been a step too far.
Donkey behaved impeccably all day, but this was the first time I experienced some fuel starvation with a more than half empty tank on accelerating out off a left hand corner.  Future update wish list gets tank baffling or a swirl pot added.
Still have to find time to perform other work that was already in the planning though, home improvement chores get in the way.
robertwwithee
Nice show.  The big cities here have emissions testing up to a certain age usually 30 yrs or greater, every state different.  I live in country but work in city so I basically get a free pass to pollute the 90 kilometer commute each way
72DutchWagon
Here are some extra "eco green" Salon impressions, more or less as a protest against Antwerp creating a LEZ (low emission zone) for the inner city, effectively banning 1 in 5 vehicles registered in that zone (!) from entering it. All over Europe cities are creating their own crazy schemes, so you never know what you're up against when driving a car older then say 15 years.
72DutchWagon
Once again Donkey went to the Antwerp Classic Salon (40th edition). On the parking lot he cuddled up to a Audi Ur-Quattro.
Other joys to be seen on the increasingly wet and muddy parking were the classics in the second image, if you look carefully you can also see parts of several recent Bentley convertibles and Porsches next to and behind them, it gives an idea of the wide variety of people that this event attracts.
Third image shows a French Ford SAF Comète Monte Carlo, which has the French version of the 239 flathead V8.
Fourth image is a rally prepped Mustang.
I'm sorry, but there wasn't a Ford 2.0 or 2.3 in sight, only Pinto connection was a Capri 2.8 from the last day they built them in 1986.
Used parts availability on these shows is getting poorer by the year, seems that everything is going by the Internet nowadays, and I don't care for stands with model cars, leather caps and goggles.
robertwwithee
He has wheels in the garage.  I seen them.  Glad to see Geert's progress on the wagon.  Blaine gets credit as I was just courier.
Glad your head lights are now shinning very brightly , please post a few photos when you install the carpet , going to look great inside , now you need some nice wheels  ;D
It's the willing helpfulness between members that makes this site special!  This is a perfect example of that!
Dwayne :)
