Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 12/13/2016 10:25 am
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 02/14/2019 06:27 pm
Date: 10/26/2020 03:24 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Windshield
Date: 01/15/2022 09:31 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 09/09/2018 03:22 pm
  • Online today: 1,166
  • Guests: 482
  • Total: 482
Duraspark 2.8?
Started by Randy Holman, August 18, 2015, 12:11:23 AM
yes they were very reliable except for the org early 76 to 77 models, a contractor made the ign module with cheep parts to make more money but they started failing , most have been replaced by now , your car came with the duraspark , did you remove it when you put in the 2.8 ?? , I do have some wiring if you need it to set it up right , I converted mine to TBI fuel injection on my 2.8 and used the TFM computer controlled Distribitor , let us know what you have now , later Blaine
enzo
Randy, therangerstation.com has an article that explains everything you need to know about the swap, including wiring mods and diagrams, all step by step.  In my experience the Duraspark is dead reliable.
The stock pinto was a duraspark set up, the later bronco II had a computer contrôléd feedback carb and dist ,  it was a pain in the butt when you had a problem with it , the fix was to rob the carb and the duraspark off the pinto , the only difference in your 2.8 over the stock pinto 2.8 is the engine block is thicker , cam journal is larger ,spark plugs ,timing cover , water pump , and some the thermostat was on the top and not the side , but will work ,
Randy Holman
I know o can find probably 100 forums that talk about this but I'm lazy and don't want to read 1,000 different comments. So what does it take / what does it mean to duraspark a 2.8. I have a 2.8 carbonated out of an 84 ranger in my wagon. Is it possible to duraspark it and what exactly will I need and what are the pros and cons. Thank you I know there are atleast 2-3 people that know about this on here.
76 pinto wagon
