Date: 09/19/2019 04:43 pm
Date: 08/30/2021 03:20 pm
Date: 10/10/2019 09:42 pm
Date: 04/20/2017 08:56 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 10/15/2017 10:03 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
  • Online today: 1,972
  • Guests: 991
  • Total: 991
R&R fender
Started by JoeBob, August 09, 2015, 09:06:10 PM
Quote from: r4pinto on August 09, 2015, 10:04:31 PM
Shouldn't need to put anything down. None of the Pintos I've removed fenders from had that on it, so not sure what it would be for.
Seals the engine bay from water spray / splash from the tires.
If you want the same stuff try a body shop.
Otherwise, silicone will work.
JoeBob
I took off right side fender. It is bolted down into a rail that frames the engine box. It appears that some sort of caulking was spread on the rail to sandwich between fender and this rail.  It might be a glue or a maybe to form a gasket between surfaces. What do I put in it's place?
Thank you
77 yellow Bobcat hatchback
Deuteronomy 7:9
