Date: 08/01/2018 01:17 pm
Date: 10/04/2019 08:43 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 07/08/2017 08:25 pm
Date: 07/04/2017 03:26 pm
  • Online today: 515
  • Guests: 289
  • Total: 289
just wasted two hours
Started by JoeBob, August 09, 2015, 04:13:14 PM
JoeBob
I did not find any gutters so I took the hood off. I used a flexible handle bottle brush and a vacuum and got the job done.Thanks
77 yellow Bobcat hatchback
Deuteronomy 7:9
sedandelivery
If you take off the fender there should be flat shaped drain "gutters" on either side of the cowl. If you take off the hood, and take the rubber hinge protectors off you should be able to get a lot out. (On EBAY right now someone  is selling a cowl cover he cut out of a Pinto, if desperation kicks in) I had good luck with what I just described. Those flat gutters get blocked up pretty easily. I live in the middle of the woods.
It has been a long time, but I recall removing both fenders and then using a thin, cheap drain snake (from the dollar store) to scrape out the area. I also used a yard stick through the vent holes.  The secret is to get as much moving at the end otherwise the debris tends to just build up. Eventually I used water to float out what didn't come with scraping, then a leaf blower to get out that which wouldn't float.  And, yes, you will get debris in the car! I've used magnetic strips and window screen to cover the area when not driving. It helps a lot.
ixplod
Taking off the hood gives you a couple of small access holes.
Tim D.
1980 Sedan - 2.3, 4-speed
JoeBob
my car sat for 14 years under a tree, I am trying to clean out leaves in the lovers in front of windshield. I took out inner fender looking for access. I took off rt side fender, no access there either. I am thinking of cutting through the fire wall. Anyone know a better way.
Thank you
Deuteronomy 7:9
