Date: 02/11/2020 12:09 am
Date: 12/09/2016 08:34 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 05/13/2021 05:29 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 02/18/2017 05:55 pm
parting out 1975 & 80 pintos
Date: 10/31/2018 12:00 pm
1979 pinto
Date: 04/19/2018 02:02 am
  • Online today: 586
  • Guests: 241
  • Total: 241
putting chrome trim in rubber molding
Started by bbeegles, August 08, 2015, 05:44:58 PM
Quote from: bbobcat75 on August 12, 2015, 10:04:16 AM
there is a tool to help - bought it and still haven't had any luck on completely installing that trim - my guess is way easier to remove glass - install trim and reinstall glass!!!
Still a pain in the neck...
Quote from: bbeegles on August 08, 2015, 05:44:58 PM
Hello, I am trying to insert the chrome trim back into the rubber molding on the back window of a 1977 pinto hatchback and am having some difficulty. I can slide the top and bottom pieces in on the straight part firmly but then can't get the corners in.  Do I need a special tool? Or is there a trick to getting that trim back in the molding?
Mine is out a bit on the bottom. If you find a trick to doing this, please post it!
I did not find any instructions in the 77 Ford manual.  I do not recall ever installing this trim, so just speculating.  I would install the trim pieces in the rubber gasket, then install the glass in the gasket, and then install the assembly into the car.  To aid installing the trim, a rubber protectant like Armorall should help make the rubber gasket to be more flexible and slippery.  Good luck.
bbeegles
trying to finish putting this pinto back together
