Date: 05/28/2017 03:20 pm
Date: 09/22/2020 11:33 pm
Date: 02/28/2018 09:18 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 03/23/2018 09:23 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
1979 pinto
Date: 04/19/2018 02:02 am
Parts Parts Parts
Date: 09/08/2018 03:13 pm
  • Online today: 586
  • Guests: 283
  • Total: 283
putting chrome trim in rubber molding
Started by bbeegles, August 08, 2015, 05:44:58 PM
dianne
Quote from: bbobcat75 on August 12, 2015, 10:04:16 AM
there is a tool to help - bought it and still haven't had any luck on completely installing that trim - my guess is way easier to remove glass - install trim and reinstall glass!!!
Still a pain in the neck...
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
bbobcat75
1975 mercury bobcat 2.8 auto
dianne
Quote from: bbeegles on August 08, 2015, 05:44:58 PM
Hello, I am trying to insert the chrome trim back into the rubber molding on the back window of a 1977 pinto hatchback and am having some difficulty. I can slide the top and bottom pieces in on the straight part firmly but then can't get the corners in.  Do I need a special tool? Or is there a trick to getting that trim back in the molding?
Mine is out a bit on the bottom. If you find a trick to doing this, please post it!
Vehicles:
I did not find any instructions in the 77 Ford manual.  I do not recall ever installing this trim, so just speculating.  I would install the trim pieces in the rubber gasket, then install the glass in the gasket, and then install the assembly into the car.  To aid installing the trim, a rubber protectant like Armorall should help make the rubber gasket to be more flexible and slippery.  Good luck.
bbeegles
trying to finish putting this pinto back together
